10-05-2022, 07:14 PM
All gauges went out!
I went to work 3 days ago, all fine barring seeing my A/C temp set at 70...don't remember switching that.
2 days ago, I used the 12V on the console with key set to acc to run an air compressor due to TPMS warning.
Didn't drive yesterday.
Today, I notice all gauges don't move and the odo is blank. After work upon start-up, the tach and speedo gauges moved a small bit, but stayed there and the odo came back on but didn't register gaining mileage.
Battery terminals are clean. The grounds that I could find are clean.
I've searched, but didn't see anything where the above happened. Seems like others have had one or two gauges go out.
Any ideas or hints before I take out the cluster? I've read Tanin Auto Electronix does repair these. Anyone have a review they'd like to share?
Thank you.
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
10-06-2022, 07:50 AM
a bad alternator will cause the same issue, check that out too. but use a voltmeter to confirm the voltage output. also alternator can read the correct voltage, but wont have the amperage. this causes alot of fluctuating output also.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-07-2022, 11:33 AM
Thank you! Can't remember if I saw that issue in my search.
10-07-2022, 01:21 PM
Just went to Autozone and they tested the alternator. Said it was working properly, but they just hooked up their tester to the battery and had the engine turned on. No load testing (head unit was already on, but wasn't asked to turn on lights).
10-08-2022, 08:44 AM
i think they need to do amperage test.
10-12-2022, 12:27 AM
I went to another Autozone and had them recheck. I had a bad battery which was replaced for free (don't know why it didn't show bad four days ago). Also asked about putting a load test on the alternator and was told with the new testing meters that its not necessary. I think I'll hit up Orielly's tomorrow morning to get another opinion. The cluster is still not working, though the odo has showed up and logging miles.
10-12-2022, 08:35 AM
check your "dome" fuse in the engine bay. also inside fuse box, check all fuses
01-25-2023, 12:04 PM
I ended up getting a unit from Tanin Auto Electronix. Everything is working fine now and the installation was pretty easy with the help of YouTube video detailing our cluster removal.
Side note: Do NOT use Griot's glass cleaner on the clear plastic. I didn't read the fine print and it ruined the one Tanin sent. I used my original which was in perfect condition and am VERY glad I didn't try and clean both at the same time!
So nice to have the gauges back!
