Old 10-06-2022, 10:20 AM #1
agb104983 agb104983 is offline
agb104983 is on a distinguished road
275k on original spark plugs
I thought everyone might be entertained by a little anecdote on the durability of the OEM NGK plugs in the 2UZFE V8.
To start, this is not about my 4th Gen but family members 4th Gen. They said it was misfiring under acceleration and check engine light was on. I put my scanner on it and it was a misfire on cylinder 2. I asked when the last time spark plugs were done and supposedly they had not been done at all from when they first got it at 60,000 miles. It now had over 275,000. And I would assume it’s fairly unlikely that they got changed prior to 60,000 miles so most likely original plugs.
So I pulled all the plugs and coils. All the other coils looked perfect except for the cylinder 2 coil which had a crack and some scorching marks indicating failure. Got a new set of Denso iridium plugs and swapped all of them out as well as replacing the damaged coil.
I’ve included some pictures for those that are interested. All eight plugs looked identical to this. Really impressed that somehow these plugs lasted 275,000 miles. Also impressive that even though the gap had eroded to be fairly large, the vehicle had still driven fairly smoothly and quietly when I drove it 5k-10k miles prior to this.
275k on original spark plugs-1adec1b2-eb34-4b26-8217-0af79dff0a24-jpg  275k on original spark plugs-cd2c58ba-d465-4b88-a117-8b720f174ea0-jpg
2008 4Runner Limited 4X4 V8(X-REAS, Factory Navigation, Backup Camera, Weathertech Floor Mats, Sylvania SilverStar Ultra Highs/Lows)
agb104983 is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 03:46 PM #2
twa318 twa318 is offline
twa318 is on a distinguished road
Just did the plugs on my 2007 @ 240k miles.
I'm the second owner and was shocked to see original plugs!
No CEL or even rough idle but my MPG had gone way down so I figured I would do the plugs and PCV valve.
Crazy that it was running as well as it did on factory plugs
275k on original spark plugs-spark-plugs-jpg
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 06:42 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
Plug gap looks like about an 1/8" or so!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
000 , fairly , miles , plugs , prior
2003 V6 Original Spark Plugs bill444 4th Gen T4Rs 10 06-21-2021 08:28 AM
210k miles on original plugs! jeremyc74 3rd gen T4Rs 13 10-22-2015 05:43 PM
Cause for Concern? original plugs @ 79K CookieRoe 4th Gen T4Rs 5 11-11-2010 10:19 AM
WTF!!!??? 60k and ORIGINAL V6 PLUGS!!?? 4RunnerStunner Maintenance/Detailing 14 07-22-2009 08:29 PM
pultar pulse plugs (not spark plugs) 3rdgengrog 3rd gen T4Rs 2 11-15-2008 04:44 PM
