Old 10-10-2022, 12:54 PM #1
ferrisDJB's Avatar
ferrisDJB ferrisDJB is offline
ferrisDJB has a little shameless behaviour in the past
ferrisDJB's Avatar
2007 4RnR Brakes
Need to do a front brake job on a 2007 4RnR. Most likely going to replace the rotors, pads and bleed the system. So, I've seen numerous responses stating OEM brake pads are the best to use. With what I need to do, I usually use RockAuto for parts. What company makes the OEM pads and rotors? The composition of the pads...are they ceramic or a blend of ceramic and copper? Also, apparently there are two sized rotors for an '07, 319mm or 338mm. This is a 2007 Sport V-6.Thanks for any help offered.
ferrisDJB is offline   Reply With QuoteReply With Quote
Old 10-10-2022, 01:02 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
OEM pads are semi metallic.
OEM brands are Aisin, Advics, and Sumitomo.
OEM rotors made in US are Brembo.
If you have the larger sport edition or limited 17" wheels then these are the parts to buy:
front brake shim kit 04945-0C030
17" 338mm brake rotors 43512-60151
front brake pads semi-metallic 04465-35290
4 pins 9024006158
pin clip 4774935040
anti rattle center wire 494735050
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
4rnr , ceramic , oem , pads , rotors
So I almost got raped by the Dealer today....brakes brakes brakes. DizzyV6P 5th gen T4Rs 36 04-28-2015 11:23 PM
2007 4runner Squeal noise (probably brakes) popalzai 4th Gen T4Rs 6 08-19-2011 03:57 PM
Will an ARB front bumper for a 2003-2005, fit a 2007 4Rnr? Chris Sandstorm 4th Gen T4Rs 1 06-03-2011 01:09 AM
Towing with Electric Brakes vs Hydraulic Surge Brakes PanicDog 4th Gen T4Rs 6 03-30-2010 08:16 PM
2007 rear brakes nedzad1 Maintenance/Detailing 2 12-21-2009 05:22 PM
