Old 12-28-2022, 05:08 PM #136
MikeinNH67's Avatar
MikeinNH67's Avatar
Originally Posted by zguy1 View Post
I have to say that my mind started thinking about every piece that I took out and whether I had missed something during the repair or reassembly.
Excellent!
I always second guess myself after a job this big, especially if it spans multiple days. I would say that is normal.
As for the idle, I think the relearn procedure is to just let it run at idle for 20 mins or something similar.
Great job on this and nice write-up to bring this to a close.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-10-2023, 06:26 PM #137
clirizarry clirizarry is offline
clirizarry is on a distinguished road
Hey guys. I was looking at the pictures that I took of the timing cover before installation. I noticed that I did not run the FIPG all the way to the bottom of the cover on both sides.
Do you think the FIPG squeezed enough to cover that gap or do I need to pull the cover?
I don't want to overthink it but wasn't sure if this would cause an oil leak.
Thanks.
It looks OK to me. You already covered the sides as well as the bottom. What you need to stop is the oil coming from the block (The brown side) to cross the flat silver side.
clirizarry is offline   Reply With QuoteReply With Quote
Old 09-12-2023, 05:06 PM #138
Jaybob7 Jaybob7 is offline
Jaybob7 is on a distinguished road
Head gasket repair / timing chain replacement?
Hi guys,
I ordered the head gasket kit and the head bolts from Toyota. I got a quote to have it installed for $1,200 + 160 to machine the heads. The mechanic suggested that I replace the thermostat and the water pump since they have to remove it anyway. I Found the Aisin waterpump at Rock Auto for $80 and the thermostat for $25.
He also suggested that it would be a good idea to replace the timing chain and the chain guides. The truck has 237,000 miles now (2004 4th Gen).
Does anyone know the part numbers for the timing chain or if there's a "kit" I can get? I want to get an idea on the pricing and make sure that I am getting the correct parts.
Is there anything else I should be replacing besides the chain and the guides? Such as the chain tensioner?
Thanks for the support!
Jaybob7 is offline   Reply With QuoteReply With Quote
Old 09-12-2023, 06:30 PM #139
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by Jaybob7 View Post
Hi guys,
Do not get the generic water pump. I learned that the hard way. The gasket is inferior and who knows about the pump. I just did my head gasket gob for the second time because I didn't pay the $160 for machining and it ended up failing in the same spot after 90k miles.
Also use OEM thermostat and radiator cap. My generic thermostat housing broke internally and caused a mess of problems while to\ing in the desert in the summer.
Consider new idle pulleys. Other than that, everything is accessible as it fails down the road.
gaber6 is offline   Reply With QuoteReply With Quote
Old 09-12-2023, 11:17 PM #140
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
I think Aison is fine for the water pump but I would probably stick with OEM. If you order online and plan ahead, you can get very good prices for OEM parts.
There is no timing kit for OEM. All timing parts are sold separately. You will get varying answers on whether or not to replace the chains, tensioners and guides. I chose not to replace any timing components but there are a lot of folks who suggest doing so. You will have to make that call. If you do so, stay with OEM. It makes zero sense to replace old working OEM timing components with aftermarket ones.
Btw. that’s a great price for the repair. If you are in the rust belt, you may need to replace the exhaust manifold studs and nuts.
zguy1 is offline   Reply With QuoteReply With Quote
Old 09-13-2023, 05:28 PM #141
Thanks for the info zguy1. I'd like to use OEM if possible. I was under the impression that Aisin was the OEM supplier for Toyota for some of it's components. Is this not the case?
The mechanic will replace the exhaust manifold studs and nuts. He looked at them and they are rusted. About the price... The wife and I are from Colorado but are now living in Panama and auto repair costs are much cheaper down here than back in the US.
Thanks again for the info!
Old 09-13-2023, 05:38 PM #142
zguy1's Avatar
zguy1's Avatar
From my limited knowledge, I believe Aisin does make a lot of OEM stuff. I don't see an issue with using that. Go for it. My OEM comment was general in nature, I've had bad luck with brands like Dorman, Timken and Moog.
Old 09-14-2023, 05:05 PM #143
MikeinNH67's Avatar
MikeinNH67's Avatar
Aisin is owned by Toyota so I would think it should be OEM. I've always been told their pump is quality for Toyotas and Hondas. Kinda like Denso is good for the electrical side of things. Of course buy from a reputable source.
Mike
03 4runner Limited
coolant , engine , gasket , head , replacement
Head Gasket Repair - or Not woodman60 4th Gen T4Rs 12 10-30-2022 08:37 AM
Repair head gasket, replace engine, or replace truck? backcountrylimo 3rd gen T4Rs 31 10-01-2020 12:45 PM
Head Gasket repair shadowdude22 Classic T4Rs 10 06-03-2016 05:58 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
Head Gasket repair KingJerd Classic T4Rs 5 04-11-2009 05:59 PM
