Old 10-15-2022, 02:01 PM #1
lathamb lathamb is offline
lathamb is on a distinguished road
X2 Power 31M Battery Posts Hit Hood
Hi All,
I'm upgrading my battery from a Die Hard Platinum 31M, and I bought an X2 Power 31M. I knew the cables would need to be extended, however the battery posts on the negative side now hit the hood. Has anyone come up with a good fix for this? I'm looking at cutting down the negative terminal, but wanted to check before I get the cut off tool out.
Thanks,
Ben; 2007 4Runner LTD 4x4 V8; OME Lift, FJ Wheels; Dual Batts, Hidden Front Hitch;
lathamb is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 12:44 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
undo the negative post, its only a bus bar that goes to the other terminal, i forgot what size bolt can go in there.
X2 Power 31M Battery Posts Hit Hood-battery-jpg
@CrimsonCountry did this
X2 Power 31M Battery Posts Hit Hood-batt-jpg
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK LTS pads F+R, Stoptech slotted rotors and stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 10:00 AM #3
Thanks. The one I Have looks quite a bit different from that one. The posts are way to the front of the battery where they were previously closer to the middle (like you show there), and they stick up a good 3/4 of an inch higher than my old DHP 31M. I don't know if they have redesigned the battery or what, but after looking around for a while yesterday, the new X2 Power 31's and the new Odyssey 31Ms look almost identical with the newer post placement.
Are you saying you were able to remove both threaded studs (negative posts), by unscrewing them from the bus bar under the case? I unscrewed the typical automotive battery terminal, that left two threaded posts sticking out of the battery that were both too tall. If I can remove those studs from the bus bar and use a shorter bolt for the terminals that might be an option.
Old 10-17-2022, 06:08 PM #4
CrimsonCountry's Avatar
CrimsonCountry CrimsonCountry is offline
CrimsonCountry is on a distinguished road
What does yours look like? I'm surprised they changed the design if thats the case.
2006 SE 4.0 4WD (click for build) : Custom, de-badged floor mats...
CrimsonCountry is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 06:53 PM #5
theladyviola's Avatar
theladyviola theladyviola is offline
theladyviola will become famous soon enough
The Odyssey, X2, and Northstar 31M are indeed all the same battery. If you convert over to just using the studs, I’d think the 31T would fit better. Otherwise I’d think you could unscrew the negative stud.
theladyviola is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 08:38 PM #6
Yea, I wouldnt think they changed designs across all brands since the 31s appeared the same a few months back.
I took everything off mine (thread posts, bus bar underneath the plastic cap and the cap itself) leaving only the threaded post holes. I bought some 1" 3/8 bolts to fasten flush terminal blocks on mine (pictured above). I also bought some shorter, threaded posts to use the OEM connectors bc I was in a hurry when installing and couldnt find my crimper (likely redo later). Everything clears and I can slam my hood shut as normal.
I've yet to make terminal covers to prevent the increased short risk given that both exposed surfaces are massive but will do that soon. That or I'll ditch the blocks and just stack the few connectors I actually use on the bolt and be done.
31m , battery , hit , hood , posts
Dead Battery - how to open the hood AlexJet 5th gen T4Rs 61 02-10-2022 05:58 PM
1999 Rear Power Window Help (Can't find an answer in other posts) PotentSeaMen 3rd gen T4Rs 6 04-09-2019 09:44 PM
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
tallest battery under the hood? Jc12 3rd gen T4Rs 12 10-29-2014 02:10 AM
Faulty hood latch causing battery drain. Celtic1888 5th gen T4Rs 6 12-03-2013 08:20 AM
