Old 10-18-2022, 07:58 PM #1
EdmundGTP EdmundGTP is offline
EdmundGTP will become famous soon enough
What's this sound??
And I don't mean the airplane in the background.
Front pass. side has been making this noise after rolling the window up all the way and letting off the up switch.
Any idea what it is?
Imgur: The magic of the Internet
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
EdmundGTP is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 08:24 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Does it do the noise no matter which switch you roll up the window with, i.e. when using the driver's door switch, I assume it does just wanted to be sure it doesn't have to do with a defective switch?
My best guess is there's some wear/flex in the regulator's bushings/joints/cables and when you release the power the flex releases and the sound is that pressure release on the joints/bushings/cables.
If not that then it could tension between the glass and rubber weather stripping relaxing when you release the power, you could try spraying some silicone spray on the weather stripping and see if that helps with the noise.
2004 Limited V8
Old 10-18-2022, 08:34 PM #3
Noise is present with both driver and local passenger switch being used. I think you're probably right.
idea , letting , rolling , switch , window
Does anyone recognize this sound?? Mouse/tapping sound from inside? theoutbackdream 4th Gen T4Rs 5 04-22-2017 12:26 AM
What is This Sound? RPC 4th Gen T4Rs 18 04-12-2015 11:19 AM
need some sound help 2004TR4-SR5 4th Gen T4Rs 1 03-12-2012 12:07 PM
Sound off-pics of ya sound systems 15boomin Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-17-2010 08:54 PM
2004 rear sound sound system pag04 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-14-2004 10:47 PM
