Old 10-25-2022, 11:26 AM #1
Syr4RinNC's Avatar
Syr4RinNC is a jewel in the rough Syr4RinNC is a jewel in the rough Syr4RinNC is a jewel in the rough
Syr4RinNC's Avatar
Question about Diff drop
Im planning to do a Diff drop. Theres no clear science or research it helps, but it cant hurt and its cheap and I keep going through CV axles.
Im not sure when the last time my mid engine skid plate has come off. I tried to remove one of the bolts and it snapped like a twig and I assume the rest are frozen on. So I believe I will not be able to support the diff from underneath with a jack.
Heres an idea and Im wondering what your thoughts are - I remove side a diff bracket bolt then slide the longer diff bracket bolt in side a. I then remove the other diff bracket bolt side b and allow the space with the longer bolt on side to slide the spacer in side b and put the longer bolt in side b. with side b secure, I remove side a bolt, slide the spacer in and torque it all down.
Do you think one bolt at a time will support the diff - or is it too heavy and too wobbly and would fall out without more support.
Thanks so much
Old 10-25-2022, 08:14 PM #2
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
That may work for the diff drop spacers but there should be, at least mine came with spacers for the skid plates where they mount to the crossmember too (the four middle bolts. Mine is a Toytec diff drop. There’s another third back mount so I don’t think it will fall out.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 10-25-2022, 09:15 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Forgot about the skid plate drop - you’re right. I’ll have to get some heat and hope I can slowly work it back and forth with out snapping all of them. In NY we are fortunate to have state inspections so maybe I’ll ask the shop while it’s in to try to remove the skid plate for me - so question is do I trust myself or the mechanic of the day who has better tools and a lift
I do need to probably change the front diff fluid
Old 10-25-2022, 10:26 PM #4
aemravan aemravan is offline
aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future
one bolt is more than enough, even partially threaded, to hold the diff in place, it won't go anywhere. As mentioned, the skid still needs to come off and be spaced down as well.
Here is an unpopular opinion from a guy who ran a diff drop kit for over a year and ultimately pulled it off... it doesn't work. Maybe if you're running a pretty big lift up front and are literally at the limit angle of your CV axles it could help, but realistically speaking, dropping the front mount points of the diff by 1" hardly results in the same drop back at the actual CV axle. Don't expect this to be some magic cure, you'll still see similar angles at full droop.
2003 Limited V8 4runner - Tacoma Front End Swap - Icon 2.5 front coilovers - Dobinsons IMS59-50575 LT Shocks w/ C59-749V springs - Coastal Off-Road Bumpers - ARB Front/Rear Lockers - 4.56 Gears - RCV front axles - Twin-stick FJ T-case swap - LC200 Steering Rack Swap
aemravan is offline   Reply With QuoteReply With Quote
Old 10-26-2022, 08:31 AM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
The diff drops sold in US are as Amerevan says, not worth the effort. The Australians have the real deal, new brackets, etc., it really relocates the diff downward, forget the name of the company that I researched, starts with a P.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-26-2022, 07:33 PM #6
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
This one?
Hilux N70 & N80 Diff Drop | Phat Bars
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 10-26-2022, 07:46 PM #7
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin will become famous soon enough
Have you tried at least putting some penetrating oil on those bolts first? I always start there then go to heat if need be but vast majority of the time penetrating oil and a little time works great.
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 10-26-2022, 07:48 PM #8
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Originally Posted by Keros View Post
Yep, that's them!
bolt , diff , longer , remove , side
Recently installed lift, question about diff drop Want24Wheel 3rd gen T4Rs 5 07-10-2015 11:09 PM
FS: 3rd gen Toytec Panhard drop & 4th gen Diff. Drop & TPMS $45,$30,$45 VT schindlerslist For Sale: T4R Items 4 01-30-2015 06:33 PM
Diff drop bolt question - Skid plate issue 5280nrg 3rd gen T4Rs 7 10-13-2012 05:25 PM
Diff drop question Park 3rd gen T4Rs 2 08-26-2012 06:11 PM
Do I need diff drop and/ or panhard drop? PitbullRescuer 3rd gen T4Rs 8 03-21-2011 08:16 PM
