txt4r
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 02-11-2012, 03:35 AM #1
txt4r's Avatar
txt4r txt4r is offline
txt4r is on a distinguished road
txt4r's Avatar
Write-up: How to Disable (Bypass) the TPMS
This can be done in 5-10 minutes. All you need is a wire connector that can directly connect two wires. What I used was a Scotchlok wire connector (see the first picture below). Here is how:
Steps (on my '05 4Runner):
  1. Disconnect the battery (Although I did not do this)
  2. Take out the screw that holds the black plastic panel located below the glove box
  3. Gently pull the black panel and it should just pop out
  4. Drop the panel and you will see that the TPMS module is right there
  5. Unplug the harness (as show in the second picture below)
  6. Use utility knife or scissors and cut the yellow type open (BE CAREFUL-Not to cut the wires!!!!)
  7. Inside the yellow type there is another layer of black type, cut that open as well (again, BE CAREFUL Not to cut the wires!!!)
  8. Now, look for two wires: the Pink-Black one (TPMS) and the White-Black (ground) wire (see below the third picture)
  9. Use Scotchlok wire connector to connect the Pink-Black wire and the White-Black wire (watch youtube Scotchlok Wiring Demo clip here: ScotchLok Wiring Connector Demonstration - etrailer.com - YouTube) NOTE: Check both channels inside the connector. If one channel is blocked, you need to cut out the plastic block to make adjustment so that the wire can go through just like the other channel).
Done! The TPMS light is now bypassed and the light will never come back on. (Note: this mod is reversable by simply removing the connector or wire a switch to turn it on or off: see TPMS light bypass switch)
Since the TPMS is disabled, be sure to check your tire pressure regularly.
Write-up: How to Disable (Bypass) the TPMS-clipboard01-scotchlok-connector-jpg  Write-up: How to Disable (Bypass) the TPMS-clipboard02-tpms-module-harness-jpg  Write-up: How to Disable (Bypass) the TPMS-clipboard03-tpms-wires-jpg
‘99 Highlander Version /Sport BLACK
‘05 Sport Edition Silver
‘22 SR5P Silver
txt4r is offline   Reply With QuoteReply With Quote
Old 02-11-2012, 04:03 AM #2
ohnoitsthecops's Avatar
ohnoitsthecops ohnoitsthecops is offline
ohnoitsthecops is on a distinguished road
Good ****
ohnoitsthecops is offline   Reply With QuoteReply With Quote
Old 02-11-2012, 01:32 PM #3
Bigrupp's Avatar
Bigrupp Bigrupp is offline
Bigrupp is an unknown quantity at this point
Bigrupp's Avatar
So need to do this. I'm sick of that damn thing being lit up. Thank you.
04 Toyota 4Runner Sport - Stratosphere Mica- Yaesu FT-8900r Quad Band Ham radio- JVC EXAD KW-AVX800- 4.88 Nitro Gears- Retrofit E-Locker (R)- ARB Air Locker (F) w/ CKMA12 compressor - ICON 2.5's w/ remote reservoirs- ICON Overland 3" rear springs- Spidertraxx- 1" Body Lift- RCI Skid Plates- 4th Gen BajaRack- GY Duratracs- 285/70R17- C4Fabrication Front Bumper w/ Smittybilt X20 10K winch and Baja Designs 30" S8 and Squadron Pro's- C4Fab Rear Bumper w/ BD Squadron Sports, Spare Tire and Dual Jerry Cans - C4Fab sliders- Dual Battery Setup- Dometic CFX65DZ Fridge
Bigrupp is offline   Reply With QuoteReply With Quote
Old 02-11-2012, 01:34 PM #4
Synister's Avatar
Synister Synister is offline
Synister is on a distinguished road
Synister's Avatar
Does this work for 06+? I had heard Toyota did something to make this type of bypass harder for newer years.
2009 4runner Trail V6, Icon 2.5 Ext travel front CO, Icon 2.0 remote resi rear shock w/ Icon springs, TC UCA, Custom Sway-bar End Links, 1.25" 4crawler BL w/ radiator drop, Cooper Disco AT3 285/70r17, ProComp 7098's, KurtFab diff bracket, Hayden tranny cooler, side-routed exhaust mod, Shrockworks Sliders, Full RCI Metal Works skid plates, Dual-Batteries, Kenwood TS-480HX HF radio, Kenwood TM-D710 VHF/UHF/APRS radio, Husky floor mats.
KJ6QDJ
Synister is offline   Reply With QuoteReply With Quote
Old 02-11-2012, 07:09 PM #5
txt4r's Avatar
txt4r's Avatar
I did not see any info saying this mod would not work for 06+. But don't take my words as I only did it to my 05.
‘22 SR5P Silver
Old 02-11-2012, 09:07 PM #6
THES0FAK1NG's Avatar
THES0FAK1NG THES0FAK1NG is offline
THES0FAK1NG is on a distinguished road
Quick question. Just want to be thorough here. Which ends of the wires do we connect? As in 2 needed wires run into the TPMS module. Do we pull the 2 wires out of the module and connect them? Or cut the two wires and connect the ends of the wires loose from the module?
THES0FAK1NG is offline   Reply With QuoteReply With Quote
Old 02-12-2012, 03:00 AM #7
txt4r's Avatar
txt4r's Avatar
Just use a scotchlok connector (as shown in the first pic) to connect the two wires (Black-White and Pink-Black). Do not pull or cut any wires.
Watch the youtube clip on how scotchlok wiring connector works. Put the Black-WHite wire in one channel and the Pink-Black wire in the other channel to connect the two wires directly.
‘22 SR5P Silver
Old 02-12-2012, 10:44 AM #8
li_runner's Avatar
li_runner li_runner is offline
li_runner is on a distinguished road
li_runner's Avatar
This is exactly the same for 06+
-Pete
07 Shadow Mica V6 Sport
Audio: Eclipse AVN 6620| Alpine PDX 4.150 & 1.600 | CDT HD62 x2 & Fiberglassed 12'' & Lots of Soundproofing
Lighting: 4300K HID, 3000k HID Fogs, LED Interior, Krager HID Driving Lights
Outside: Daystar 2.5/1.5, 285/60R18 Toyo OC AT | T&H High Bull Bar
li_runner is offline   Reply With QuoteReply With Quote
Old 02-12-2012, 11:33 AM #9
Radial GT's Avatar
Radial GT Radial GT is offline
Radial GT is on a distinguished road
Radial GT's Avatar
Good stuff, I will be doing this TODAY. That light drives me nuts. My spare tire sensor is shot. I understand that 100% of soccer moms do not check their tire pressure, but to make it such a finicky system to keep running is not acceptable. Our 04 Sienna uses the ABS sensors to tell if one tire is running low, which is a GREAT way of performing this task. Why they decided to over complicate the system is beyond me.
I do not have any of those lock deals, but I plan on soldering a wire across the two wires. The next owners don't know it yet, but I am making this fairly permanent.
Thanks for the write-up!
04 Limited 4WD V8 Silver All Stock
93 RX7 Twin Turbo Non-Sequential
Radial GT is offline   Reply With QuoteReply With Quote
Old 02-12-2012, 08:50 PM #10
txt4r's Avatar
txt4r's Avatar
That's right -- you do not have to have a scothlock connector; it should work just fine as long as those two wires are connected. Soldering a wire directly across the two wires is a good idea! Good luck!
Also, you can add a switch some where between the two wires to turn the TPMS system on and off.
‘22 SR5P Silver
Old 08-05-2012, 02:08 PM #11
geedubcpa geedubcpa is offline
geedubcpa is on a distinguished road
Thanks
Just did this on my 2005 4runner - pesky little flashing light is gone. I have been checking my air pressure for 35 years without an ECM telling me I am low, so why start now.
On my Honda Oddysee I have never had the light come on an be accurate - it comes on about once per year during cold days and gives me false alarm.
geedubcpa is offline   Reply With QuoteReply With Quote
Old 08-05-2012, 03:02 PM #12
zstampe's Avatar
zstampe zstampe is offline
zstampe is on a distinguished road
zstampe's Avatar
GREAT write up. I'm surprised that i've never seen this. I will be doing this to mine once I get new wheels.
2006 SR5 4x4 My build: http://www.toyota-4runner.org/4th-ge...ml#post1104330
"We're the middle children of history man. No purpose or place. We have no great war, no great depression. Our great wars a spiritual war....our great depression is our lives. We've all been raised on television to believe that one day we'd all be millionaires, movie gods or rock stars. But we won't. And we're slowly learning that fact....."
zstampe is offline   Reply With QuoteReply With Quote
Old 08-05-2012, 03:12 PM #13
BReardon21
Guest
Posts: n/a
BReardon21
Guest
Posts: n/a
great Write Up!
Old 08-05-2012, 04:46 PM #14
ChaosStarter ChaosStarter is offline
ChaosStarter is on a distinguished road
Couldn't you just pull the bulb in the cluster if you didn't want to look at it and not use the system?
ChaosStarter is offline   Reply With QuoteReply With Quote
Old 08-06-2012, 07:13 PM #15
blk-4runner blk-4runner is offline
Banned
blk-4runner is on a distinguished road
Banned
Did it on my 07, and it works! Thanks.
blk-4runner is offline   Reply With QuoteReply With Quote
TPMS light bypass switch Kmvreter 4th Gen T4Rs 84 07-28-2023 07:31 PM
TPMS Disable 05Rrunner 4th Gen T4Rs 13 06-13-2011 06:48 AM
TPMS Disable for 5th Gens Tgrds 5th gen T4Rs 0 04-26-2010 10:38 PM
Disable TPMS, mybenje 4th Gen T4Rs 8 02-19-2009 10:41 PM
TPMS Disable dheeter 4th Gen T4Rs 0 11-18-2008 01:50 PM
