10-26-2022, 08:48 PM
Ignition ON when using a Pressure Brake Bleeder?
Question in title. Proper brake bleeding require ignition (but not engine) to be ON. Does the same apply when using a pressure bleeder like the one Motive makes?
'08 Silver SR5 V6 4x4: OEM+
10-27-2022, 08:13 AM
I just tried this the other day, and I was able to push fluid through the system with and without the key in.
In the interest of making sure I removed as much fluid as possible, I ended up doing a first round with the key off, then turning it on and pumping the pedal a few dozen times before I bled each corner again.
10-27-2022, 08:23 AM
Fronts - engine off ignition off. Pump brake pedal slow and smooth. Try not to press brake to the floor. It could damage master cyl seals.
Rears - no brake pedal pumping. Open bleeder, turn key to accessory, allow brake motor to run until it stops, igintion off, repeat ignition on. Let the the truck pump the fluid.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
10-27-2022, 09:12 AM
Real Name: Rich
Real Name: Rich
I have a 2004 SE V8 and I'm in the process of bleeding mine now. I tried using a Mityvac brake bleeder on the rear lines but it wasn't effective.
I used a Mityvac 830 to draw most of the fluid from the reservoir front section, then refilled with Prestone DOT 3 MAX. I wanted to replace the fluid in the lines, since it had never been done. I used the brake pump for rear calipers.
I used a 17 oz. empty/clean water bottle with the clear PVC line from the Mityvac feeding through the bottle cap to the bottom, a couple inches of fluid in the bottle. I put the rear axle on jack stands, did one caliper at a time. I put the bottle above the axle, hose to the caliper bleed valve, opened the valve.
Ignition on (idiot lights on), engine not started, brake motor will run and stop. I pressed the brake pedal down and the pump ran. (If you do this too long the alarm beeps.) After about 6-7 seconds I let off the brake and checked the bottle and reservoir levels. (Do not let the reservoir go below minimum.) When I saw the fluid get lighter I felt the new stuff was in that line and did the other side. I had to empty the bottle once, refill reservoir twice for each side.
I tightened up the bleed screws, removed the bleed tube and bottle, removed jack stands and lowered the car.
For the front wheels I used the Mityvac, ignition off. Standard brake bleed; turn on Mityvac, open bleeder valve, draw fluid, close valve, check reservoir. Repeat on the other side. TIP: I use a small amount of beeswax on the bleeder screws to make stronger suction, fewer air bubbles.
I have a good brake pedal, no leaks.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
10-27-2022, 09:40 PM
Great- I'll give this a shot in a few days. Good tip on not using the pressure bleeder for the rears.
10-28-2022, 11:09 AM
Real Name: Rich
Real Name: Rich
I've used only the Mityvac a couple of times and it just doesn't work well on the rear calipers. I let the pump do the work this time and it was a huge improvement. You don't need to push hard/far on the brake pedal. When you turn the key the pump builds pressure and stops. Then push down and you will hear the pump start. Hold for 7-8 seconds then release brake pedal (if there's a warning beep let go). Pump will run until pressure is up again then it will stop. Check the reservoir and the drain bottle.
On the fronts I found the beeswax (cheap, small jar of it in the cosmetics aisle where you find ointments, topical vitamin E bottles, night creams) helps seal the threads. I also pull or push on the bleeder valve and will find a sweet spot where the vacuum is best when Mityvac (bleeder) is running.
I replaced my rear bleeder valves. They were rusty where you connect the tube and making poor contact. They are a different size than the fronts. I also put beeswax on those new threads. I've had those bleeders rust so bad on another car I had to replace the caliper.
Good luck
Rich
Kentucky
10-28-2022, 11:32 AM
Yes, ignition on.
10-28-2022, 07:54 PM
FSM instructions for bleeding brakes
10-29-2022, 09:58 AM
Real Name: Rich
Real Name: Rich
Odd that it doesn't specify a brake bleeding sequence. It says front first, then rear, left or right doesn't matter? I wonder if there is a change within the 4th gen model years
Rich
Kentucky
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
