Old 11-05-2022, 11:44 AM #1
rpinkstn's Avatar
rpinkstn rpinkstn is offline
rpinkstn is on a distinguished road
rpinkstn's Avatar
'06 Sport brake squeal
I know there are a lot of threads on this subject and I have skimmed through a bunch of them, but didn't find a solution. I may have missed it. Thanks for reading.
2006 4Runner Sport 2WD, V6
This was originaly my DD, but I gave it to my daughter when she started driving. It has a recurring brake squeal when applying light to moderate (normal) brake pressure. It's worse when cold, gets a little less noticeable when the brakes warm up but never goes away and is still pretty loud even when the brakes are warm. I have not been able to determine where the noise is coming from (front, rear, left, right).
I replaced the pads and rotors before I handed the keys to my daughter. I installed Akebono pads and Raybestos rotors at all 4 corners. I followed Akebono instructions and applied disk brake quiet on the back of the pads. At this point I omitted the Toyota anti-squeal shims because the Akebono pads had shims already. The brakes were perfectly quiet for the first 4-6 weeks but then started squealing as described above.
At that time I figured the brakes were making noise because I didn't install the Toyota style anti-squeal shims. I purchased new Toyota shims directly from Toyota for the front and rear. Took everything apart, cleaned off the disk brake quiet compound, and followed the Toyota recommended procedure for installing the Toyota shims with liberal amounts of caliper grease. Put everythign back together and the brakes were perfectly quiet again for several months. But now the squeal is back, the same as before.
The pads and rotors appear to be wearing nicely, smooth and evenly. The brakes feel and work great. So why do they squeal?
rpinkstn
'16 4Runner "Trail"
rpinkstn is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 03:44 PM #2
rpinkstn's Avatar
rpinkstn's Avatar
bump.
rpinkstn
'16 4Runner "Trail"
Old 11-09-2022, 09:45 PM #3
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
What kind of Akebono pads are you running (regular or high performance)? Sounds like my situation. Have tried brake quiet and shims and still have a squeal.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 11-20-2022, 09:00 PM #4
rpinkstn's Avatar
rpinkstn's Avatar
Berty_K - I'm running just stock replacement Akebono pads at all 4 corners. Very puzzled by the issue. It was gone for a while after I installed the shims, but came back. Temperature doesn't seem to make a difference.
rpinkstn
'16 4Runner "Trail"
Old 11-21-2022, 09:18 AM #5
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I have a Highlander that I can't solve the squeal on left rear. Had it apart several times and it still does it. Weird!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
rdruss is online now   Reply With QuoteReply With Quote
brake , brakes , pads , shims , toyota
'03 Brake Booster Squeal Ducksrus 4th Gen T4Rs 4 07-02-2023 05:00 PM
SOS brake squeal Dirtrider216 4th Gen T4Rs 3 09-17-2017 02:25 AM
SR5 brake squeal Wis4 5th gen T4Rs 7 12-19-2014 06:16 AM
Brake squeal emmwhat 4th Gen T4Rs 5 07-22-2013 03:09 AM
New brake squeal help please.... 2K34R Problems & Warranty Issues 18 06-08-2008 05:46 PM
