Old 11-11-2022, 02:16 AM #1
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
Do anti rattle clips fall out on their own?
I have been chasing for a front end clank over bump for about a month, and finally found out it was passenger side anti-rattle clip missing. After installing the clip, the rattle is 95% gone. Over most bumps it is completely quiet, the only exception is driving down a 5 inch curb, and then it makes a tiny bit of noise.
I never thought it was the brake. I had new front pads installed by the dealer (huge discount), so I assumed they did put new anti rattle clips back on. Has anybody ever found their anti rattle clips missing when you're *certain* that you installed them correctly? or was it just a knuckle head mechanic at the dealer?
stevelikesrhino is offline   Reply With QuoteReply With Quote
Old 11-11-2022, 07:08 AM #2
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Maybe they never put them back on?
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 11-11-2022, 09:01 AM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Be glad you found the problem, you'll never know what happened. Be glad.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 11-11-2022, 02:11 PM #4
Thanks for replying.
That's what I suspect too. Can't trust dealers anymore
I am glad I found it, it was so freakn embarrassing when I drive by the neighborhood and all you hear is *clank* *clank*
Old 11-11-2022, 03:18 PM #5
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Generally speaking, I've never had one of them fall out all by themselves. That said, it is relatively easy to incorrectly seat one of them if you're not careful with your disassembly and cleaning and have this cause one to fall out.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 11-11-2022, 06:40 PM #6
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
If they are put in correctly, no, they won't just come out on their own. But it's possible the part that gets secured behind the slide pins isn't in the right spot.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 11-11-2022, 09:01 PM #7
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Mine have fallen out several times. Mostly when I've been off-road though. One time it was partially still attached but sticking out and rubbing on the inside of the rim, making an awful noise.
Sent from my moto g stylus 5G using Tapatalk
techno is offline   Reply With QuoteReply With Quote
Old 11-12-2022, 07:22 AM #8
Sounds like I need to get some spares...
Old 01-19-2023, 05:08 AM #9
Update: left side anti rattle clip fell out, probably after the last offroad trip. So yeah they do fall out. Driver front clanks over bumps, and the noise disappear when depressing brake.
Old 01-21-2023, 10:42 AM #10
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
The anti-rattle spring routes through the pad retaining pin...when installed correctly. Impossible for it to fall out completely, but the ends could come unclipped from the pad slots I suppose. Haven't had this happen on mine, but I've never been off-roading either.
waypoint is offline   Reply With QuoteReply With Quote
Old 01-22-2023, 06:48 AM #11
Will check the installation this time. It might have rubbed onto something and dragged out, idk.
Old 01-23-2023, 06:25 PM #12
djpope09 djpope09 is offline
djpope09 will become famous soon enough
I was having some brake grinding noise recently and took off one front wheel to inspect the pads and the anti rattle clip was missing. I'm the last one that touched the brakes and I know I installed (correctly I think). Not sure what happened to it, maybe they become brittle over time and break off?
I had extra slide pins and anti-rattle clips from the last brake job so I installed those and made sure the clip was in correctly. I guess we'll see if it falls out again. The missing clip wasn't the source of the grinding as it ended up being the rear brakes making noise, I just thought it was odd that the clip had fallen off.
djpope09 is offline   Reply With QuoteReply With Quote
Old 07-02-2023, 01:16 PM #13
highalti2d highalti2d is offline
highalti2d is on a distinguished road
I'm experiencing a similar issue with the rear anti-squeal shims falling out. I purchased a 2006 SR5 which you could hear a squeak-squeak-squeak from the left rear wheel while driving without brakes being applied.
The previous owner had the rear brakes done at a local $99 shop. Upon inspection, I found one upper anti-squeal shim missing (assumed they must have forgot to install it during the last brake job). I purchase a new shim kit at Napa and installed new pads/shims, cleaned and greased slide pins, etc.. The noise was gone and all was good.
Several months later, the squeak returned so I pulled the wheel and found both new (Napa) upper caliper shims pushed outward. I re-installed the shims and greased the slide pins which resolved the squeak. A week later, the squeak returned and I can see that the upper shim fell out and is missing.
I'm reaching out to see if anyone has any advice regarding troubleshooting this further. Thanks.
Update: I re-seated all rear anti-squeal shims (had to lightly bend some of the little tabs for a snug fit). Over 5 months have passed without any issues.
highalti2d is offline   Reply With QuoteReply With Quote
anti , clips , installed , missing , rattle
Use two Anti-Squeal Clips instead of one for brakes? Rpede 5th gen T4Rs 3 03-11-2021 09:22 PM
Anti-Rattle Spring -Front Brake Calipers spawn General Discussions 3 12-02-2015 11:11 PM
Tundra brake anti-rattle clips djbrand1 3rd gen T4Rs 12 12-27-2012 04:00 AM
Anti-Rattle Spring problem... Zander1205 3rd gen T4Rs 1 08-27-2008 04:53 PM
