11-11-2022, 02:16 AM
Do anti rattle clips fall out on their own?
I have been chasing for a front end clank over bump for about a month, and finally found out it was passenger side anti-rattle clip missing. After installing the clip, the rattle is 95% gone. Over most bumps it is completely quiet, the only exception is driving down a 5 inch curb, and then it makes a tiny bit of noise.
I never thought it was the brake. I had new front pads installed by the dealer (huge discount), so I assumed they did put new anti rattle clips back on. Has anybody ever found their anti rattle clips missing when you're *certain* that you installed them correctly? or was it just a knuckle head mechanic at the dealer?
11-11-2022, 07:08 AM
Real Name: brian
Real Name: brian
Maybe they never put them back on?
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, General Grabber ATX 275 55 20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
11-11-2022, 09:01 AM
Real Name: Ron
Real Name: Ron
Be glad you found the problem, you'll never know what happened. Be glad.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
11-11-2022, 02:11 PM
Thanks for replying.
That's what I suspect too. Can't trust dealers anymore
I am glad I found it, it was so freakn embarrassing when I drive by the neighborhood and all you hear is *clank* *clank*
11-11-2022, 03:18 PM
Generally speaking, I've never had one of them fall out all by themselves. That said, it is relatively easy to incorrectly seat one of them if you're not careful with your disassembly and cleaning and have this cause one to fall out.
11-11-2022, 06:40 PM
Real Name: Bob
Real Name: Bob
If they are put in correctly, no, they won't just come out on their own. But it's possible the part that gets secured behind the slide pins isn't in the right spot.
2008 SR5 4WD (@280k!!)
11-11-2022, 09:01 PM
Mine have fallen out several times. Mostly when I've been off-road though. One time it was partially still attached but sticking out and rubbing on the inside of the rim, making an awful noise.
Sent from my moto g stylus 5G using Tapatalk
11-12-2022, 07:22 AM
Sounds like I need to get some spares...
01-19-2023, 05:08 AM
Update: left side anti rattle clip fell out, probably after the last offroad trip. So yeah they do fall out. Driver front clanks over bumps, and the noise disappear when depressing brake.
01-21-2023, 10:42 AM
The anti-rattle spring routes through the pad retaining pin...when installed correctly. Impossible for it to fall out completely, but the ends could come unclipped from the pad slots I suppose. Haven't had this happen on mine, but I've never been off-roading either.
01-22-2023, 06:48 AM
Will check the installation this time. It might have rubbed onto something and dragged out, idk.
01-23-2023, 06:25 PM
I was having some brake grinding noise recently and took off one front wheel to inspect the pads and the anti rattle clip was missing. I'm the last one that touched the brakes and I know I installed (correctly I think). Not sure what happened to it, maybe they become brittle over time and break off?
I had extra slide pins and anti-rattle clips from the last brake job so I installed those and made sure the clip was in correctly. I guess we'll see if it falls out again. The missing clip wasn't the source of the grinding as it ended up being the rear brakes making noise, I just thought it was odd that the clip had fallen off.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
