Old 12-21-2022, 06:21 PM #16
Real Name: Skip
Real Name: Skip
Originally Posted by LiquidFlame View Post
Well... Even toyota couldn't figure out what's wrong with it. They agreed its not a normal noise, but said it didn't seem to be anything mechanical and should be fine to drive.
What do you guys think? Should I continue to dive into this and figure out what it is? Or should I just let it go? My fear is that it decides to grenade when I'm camping in the middle of nowhere.
This is a second vehicle, so I'm thinking I'll drive it around to and from work for awhile to see if anything changes.
Did the Toyota dealership look at that one valve with little clearance, if so what did they say, if not what's the latest on that issue.
That valve would be my most worry on keeping on driving it at this point, if that doesn't get corrected you could as mentioned end up burning that valve and that means pulling the head to replace it, a lot of work to do that, getting it to have proper clearance can be done without pulling the head by using compressed air via the spark plug hole to hold the valve in place to remove the spring, but it will still require a lot of work removing the cam to replace the lifter/cup with one that will correct the clearance issue.
2004 Limited V8
engine , issue , noise , passed , start
VSC TRAC, VSC OFF, and Check Engine Light, shaking, and noises. MattJakobs 3rd gen T4Rs 10 10-10-2014 07:07 PM
opinions on noises, please assist ECMgarrett Classic T4Rs 5 12-20-2008 06:51 PM
Not so nice engine noises!!! croatiangirl74 Problems & Warranty Issues 12 08-15-2007 01:00 PM
