Real Name: Ron
Real Name: Ron
I've not seen a relocation kit for the V8, nor do I think it's needed, pretty simple access and I don't see it as messy, just put a pan under the filter after you crack it loose and let it drain for a minute or so and remove. No mess.
I don't run a front skid so that's probably where you get the mess.
Relocation kits introduce some delay in getting oil to the engine and allow for more places to leak.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
