Old 11-23-2022, 04:26 PM #1
mpierce9 mpierce9 is offline
mpierce9 is on a distinguished road
4th Gen bright beam won't power on in manual mode
Good morning. Thanks in advance for the response.
I have a 2003 4th gen 4runner. Stock headlight setup.
The issue:
When my headlights are in the on position set to low beam - no issues.
If I snap the light stick forward into the bright position the bright lights do not power on, the fog lights do turn off as expected.
If I pull the stick back into the manual bright position (where you have to hold the stick back), the bright lights will power up and work great.
Some diagnosis:
When the low beams are powered both sockets on either plug show 12v powered on.
When the high beams are powered on one socket turns to ground while the other is at 12v. This is the case on both bright light plugs.
All fuses are in place and good.
Both bulbs are good (and new) (rated at 9 OHMs resistance)
I've attempted multiple good bulbs.
The main question:
What would be causing my bright lights to power on in manual mode on the stick (Pulled back) but not power on when the stick is in the forward position?
mpierce9 is offline   Reply With QuoteReply With Quote
Old 11-23-2022, 04:54 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
The issue:
Some diagnosis:
The main question:
My best guess would be the switch gone bad in the high beam on position.
I would get out the multimeter and test the switch in the on position, you may have to remove it to test it if you can't get to the connections
2004 Limited V8
Old 11-23-2022, 06:28 PM #3
Thanks for the comment. Any direction on where the switch is physically located? I'm not very open to tearing my steering column apart, but if it's accessible i'd like to give your suggestion a try.
Late edit: I have googled and look amog the forum for wiring diagrams of this but cannot seem to find them. any help is appreciated.
Old 11-24-2022, 01:50 AM #4
Real Name: Skip
Real Name: Skip
Unfortunately it is in the steering column, what all has to be done to remove and or test it I don't know but a Toyota shop manual would have the procedure to remove and replace it.
2004 Limited V8
Old 11-28-2022, 08:05 AM #5
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
steering wheel cover is only held on by 3 screws i think.
you might have to take the air bag out, the steering wheel, the spiral cable to to get to the stalks.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK LTS pads F+R, Stoptech slotted rotors and stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 11-28-2022, 06:49 PM #6
Real Name: Skip
Real Name: Skip
I was looking at my steering column and the bottom trim piece behind the steering wheel can be easily removed, turn the steering wheel about 90 degrees and there's 2 screws that you can't see until you turn the wheel, there maybe some more on the bottom of the trim piece but I didn't look, once that bottom trim is off you can see the bottom of the light switch, not sure if it can be removed at that point or not, but at least you can see what else may need to be removed to get it out, or you may be able to test the switch at that point without removing the switch.
2004 Limited V8
Old 11-28-2022, 06:56 PM #7
riceandpho's Avatar
riceandpho's Avatar
now the question is, is he doing this high beam mode with the "key in the on position"?
some functions will need the "key to be in the on position".
was all this done with the key out of the ignition?
Old 12-13-2022, 08:23 AM #8
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Hello all ,
I want to bring this topic up to the top because I too am having the same issues. Regardless of the key in the ignition or engine running position, the headlight high beam should be operational at any time.
I do have one hand however and that is that my dome light fuse keeps blowing. I looked at the EWD diagram but wasn't able to figure out the connection between dome light fuse and high beam. Like the OP, flash to pass works just fine but turning on the high beams independently does not work.
As you can see from the EWD, flash to pass connects the terminal HF from the body ECU. I need to understand what is HF as it is not in the abbreviation list.
Sent from my SM-G981U1 using Tapatalk
Attachment 401648
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 with whole bunch of stuff!
alia176 is offline   Reply With QuoteReply With Quote
bright , good , position , power , stick
Auxiliary high-beam tap to relay, lights flickering in DRL mode mynameistory 5th gen T4Rs 1 03-03-2020 09:36 PM
Hard wire dash cam and retain auto on feature + constant power for parking mode? Lamer 3rd gen T4Rs 14 02-03-2018 10:25 PM
Bright Headlights - too bright? eviele 4th Gen T4Rs 15 11-06-2014 03:34 AM
How do I find the high beam power lead? farmerjon 3rd gen T4Rs 40 12-21-2012 09:18 AM
ECT tranny 'power' mode bmanning 3rd gen T4Rs 6 10-11-2005 05:53 PM
