10-10-2015, 11:05 PM
Instrument cluster not working, help!
I finally finished putting in a subwoofer and adding two JL amps to my kenwood aftermarket system. Everything put back together and initially I noticed that my dash light/ dimmer was out. I checked the fuses and two 10 amp fuses were out so I replaced them and the light came back on. I also did the zero pony calibration . Now the whole cluster (speedometer, tach, gas gauge, odometer all do not work. I checked all the fuses and they were ok. What am I missing?
2003 SR5 V8, Michelin Premier LTX, new in 2017. Kenwood DDX 371, Kenwood CM 220 Back up camera, hands free. Infinity front and speakers, I added soundproofing insulation in doors. Brand new dash (than you Toyota) , Weathertec mats and window deflectors,Philip HID fogs in projector housing upgrade. Morimoto D2S Bixenon projector headlight upgrade mod, LED interior lights swap. LED signal bulbs, LED driving lights,Satoshi grill ( (done by Gaterose) , JL 300W front and JL Audio 200W rear amps and JL 7 inch subwoofer. 163,000 miles . For sale $6000.
10-11-2015, 10:25 AM
Please help. I did a search and I can only find issues with individual gauges posted , not whole cluster. An additional fact is that digital odometer as well as the "computer ", where it spews out exaggerated mpg's, range etc is also completely blank but lighted. Did I fry something major ? All the gauges are resting at the below zero pins. I rechecked ball the cabin fuses (two had been blown and they are good. Are there other fuses in the engine compartment in a 2003 V8?Help needed please!
10-11-2015, 10:37 AM
Real Name: Ed
Real Name: Ed
Reminds me of when I fried my ECU when installing my HIDs.
1) Where did you tap power for your 2 amps?
2) Fuse to the amps the correct one?
3) Are the grounds ok?
4) Is the source (where you tapped for power) capable of feeding your amps power? (ex: you tapped a courtesy light to power 2 amps............. not good).
5) If all ok, then, disconnect the battery, wait a few minutes, reconnect. Can't hurt.
Can't say much else, hope you find the culprit. Hopefully it's something simple.
Good luck
hope this helps
10-11-2015, 11:22 AM
Good luck
hope this helps
Both amps wired directly to battery and grounded to frame. Fuses for amps inline with power line and are large fuses provided with amp kits. The power and ground wires are the same gauge as my battery cables. I will try disconnecting battery once my wife brings the truck back from taking tha dogs to the beach. We are using the gps for the speedometer right now.
10-11-2015, 01:04 PM
Well, dogs had a great time on the beach but disconnected the battery cables left them off for one half hour but still no function of any of the gauges or computer. I wonder if I did the zero point calibration wrong and screwed up something because the gauges were working fine (dimmer light was just out) until I did the zero pint calibration and replaced two 10a fuses that were out (lower right, can't remember exact pin#'s.i
Reason: Add dog pix
10-12-2015, 08:02 AM
unhook the dimmer wire from radio. check dome fuse and tail fuse, i think another one too. do u hve a dmm or test light to check all fuses.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-12-2015, 08:28 AM
Real Name: Nathan
Real Name: Nathan
Sounds like you may have run your dimmer wire from your head-unit to a 12v source. If you disconnect your head-unit... do the gauges work? Are the fuses blown again?
10-12-2015, 01:45 PM
Thanks for the reply . The gauges and head unit were working together. I did another search and someone had a similar problem and apparently there is one ground (brown or brownish wire) for the whole instrument cluster and it is beginning to sound like I screws this up somehow. I won't be able to get to the truck until tonight. I went through all the fuses unless it could be the "type C" fuse which I don't know how you can tell if it is blown.
05-16-2016, 09:53 PM
Same Problem: instrument cluster not working following radio install
Hi there. I am having the exact same problem you had here. What was your solution?
Purchased an '03 Limited two days ago. Have been tuning it up before a cross-country trip back to school in two days.
Took apart the dash and installed my own radio. Radio works perfectly. Also painted dash with black truck bed liner. Looks awesome.
I put the dash all back together and turned on the car to find that the instrument cluster was not working. No lights, no odometer, no movement of the gauge hands.
Was there a wire cluster I did not connect again?
When I took the dash apart, I did not go past the instrument cluster.
All the lights work, the turn signals work, the radio works, etc. I checked fuses and spun the dash light. The problem is that the entire instrument cluster doesn't function.
I've attached an image. Let me know what y'all think!
05-17-2016, 12:47 AM
check the dimmer, and also the dimmer wire, the harness you might be using gives a orange, and orange white, i just leave them capped off.
10-24-2016, 01:22 PM
Having the same issue hear, was this ever solved? If so can you please post solution? Thanks.
10-18-2017, 10:04 PM
04 4runner
Did you find the problem?
05-01-2018, 02:26 PM
Turned out my issue was related to a corroded ground wire that was severed. Check the ground attached to block on passenger side.
I had my head gasket replace shortly before the issue and the ground had to be disconnected, doing so seemed to irritate the corroded wire even more and eventually just went, started with some flickering.
09-29-2020, 01:28 PM
Could you please describe where that ground wire is? I randomly am having a similar issue. Entire cluster is out/backlights not working. Dimmer switch and radio lights all work as normal. Not sure where to start with this. Thanks in advance
11-28-2022, 01:19 PM
Real Name: Mason E.
Real Name: Mason E.
bringing back the dead on this one, just did the heads myself this last week and started it right up but kind of the same issue. I had let it run since the zero restart for about an hour at idle and jumped in and drove it around the neighborhood a few times just making sure I didn't have any leaks and such and it ran good but noticed that the gauges were dark but I was getting a read of temp and speed and rpm at least. I am at work currently and wifey took the kids to school today but she sent a pic with the whole dash off and the mile avg display under the radio was not reading as well. I do remember re-attaching the grounds on the passenger side (there are two on the head its self and one on the sheet metal just left of the block looking at the motor from the front of the car) but I think maybe one of them came loose again but I will update here just incase this happened to anyone else to see if I can fix it. the car was sitting battery-less for about 8 days before i got it started after the head work I did
