Old 12-05-2022, 10:52 AM #1
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Where are the "foot lights" that I found on the EWD?
I have a Sports edition so maybe I don't have these lights?
I'm trying to figure out what's causing my dome light fuse to blow.
- disconnected all door lights
- " both dome lights
- " both visor lights
This has been a random issue and I don't think it's in the lighting circuit. Let me disconnect the factory alarm to see if that does anything. The only other thing the dome light fuse supplies power is the HVAC control panel. The clock, and mpg are resetting to zero after turning off the engine each time.
Where are the "foot lights" that I found on the EWD?-foot-light-upload-jpg
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 12-07-2022, 12:51 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Your Body EDC and Skid Control ECU also run of that 10A Dome Fuse. You could have a short there too.
I'm not sure if all cars come pre-wired ready for courtesy lights. I think only Limited gets those.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 12-07-2022, 01:05 PM #3
Interesting info, thanks for that. I overlooked those systems being fed by the same dome light fuse. My traction control works normally so that system is ok but let me see what's up with the body EDC. That dome light fuse serves a lot of circuit, like cruise control, engine control, tail light, power window, VSC, air conditioning, etc., and yet, they all work normally minus couple of things.
This is interesting!
Where are the "foot lights" that I found on the EWD?-dome-light-fuse-serves-all-these-ckts-jpg
Old 12-07-2022, 04:48 PM #4
Have you repaired or modified anything recently? Wiring issues don't usually happen at random.
Do you have rats under your hood at any time?
Old 12-11-2022, 09:56 AM #5
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Since you have the wiring schematic unplug each system one at a time, till the fuse stops blowing. that should narrow down what item is causing the issue. Does it happen when you open the door. If so you might have a bad door jamb switch. GM s' were famous for this.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 12-12-2022, 11:21 AM #6
Yeah, I've done that to no avail but I haven't unplugged the rear tailgate harness because I need to open it quite frequently.
All door switches are negative switched and there's no way for them to short to positive from what I've seen. I mean, it's a stupid spring and a metal tab, LOL!!
The fuse won't blow for weeks or days then it'll blow quickly. I've been using a resettable 10am fuse to play with diff circuits. I tried unplugging all door switch/window switches, removed light bulbs and couldn't get the stupid fuse to blow.
On another day, I put the same resettable fuse in the fuse holder and BOOM, it tripped. So, it's been a challenging journey for the last two years or so. I'm not going to keep the resettable fuse in there full time, just for troubleshooting purposes.
Old 12-12-2022, 11:23 AM #7
The answer is yes to both! I haven't had mice under the hood since I"ve installed those blinky/ultrasonic thigns under the hood.
The only "mod" i've done is to add a tiny LED strip on the upper tailgate for additional lighting. I've since unplugged it and I still have random fuse blowing.
That dome light fuse serves a lot of systems, from what you can see up above. Thankfully, I only lost the remote lock/unlock, fuel econ meter and of course, the dome lights so far, knock on wood. Everything else is workign swimmingly.
Maybe I'll unplug the alarm box, which I think is under the seat and see if that improves things.
dome , factory , light , lights , thing
PDX, OR: AOB "LED Light Bar" and "Rear Lights" Switches - Blue pbcolt For Sale: T4R Items 4 03-26-2018 06:45 PM
FS - Thule Podium "Foot" Roof Rack System - Louisville, KY manderson1 For Sale: T4R Items 0 05-20-2015 04:28 PM
Weird problem: "VCS OFF" and "VSC TRAC" lights, and throttle lag poser 3rd gen T4Rs 7 03-10-2015 05:22 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
"fog lights", front "grill?", and sport model questions mkingphoto 3rd gen T4Rs 2 03-31-2007 09:47 AM
