Old 12-08-2022, 11:14 AM #1
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
Suspension Refresh
So i have the bilstein/ome combo coming in today but while i was in there i wanted to refresh the LCA, UCA with new bushings, etc. Have a little bit of wobble in the steering wheel, and when i'm going over bumps, steering feels a little loose.
so i have on the list
Energy Suspension Bushings Front set
Energy Suspenion Bushings Rear Set
Energy Suspension Rear Shock absorber bushings
(2) moog Front ball joints
(2) moog lower ball joints
(2) AcDelco Front shock absorber bushings
Energy Suspension rear shock bushings
anything i'm missing or i should consider replacing while i'm in there. my drivers boot is torn so i plan to do that at the same time.
As well as paint and rebuld the front calipers, while i have all that stuff off.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 09:10 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Sounds like you're in for a fun time!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 12-09-2022, 09:46 AM #3
my back is not looking forward to it....
Old 12-09-2022, 09:56 AM #4
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Get the Sankei/555/Altrom Ball joints. They're same as OEM.
Here's a link to the lower: Just a moment...
And the upper: Just a moment...
To confirm you order the correct one, throw in your make and model on the NAPA site and search for "555 upper/lower ball joint".
The Sankei/555/Altrom is the OEM supplier. Moog makes good stuff, but the OEM is better.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 10:55 AM #5
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
^+1 on not going Moog.. haven't had any luck with a lot of Moog parts holding up long term, definitely not nearly as long as OEM stuff..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 12-10-2022, 10:25 PM #6
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
If the cv is coming out for a boot I’d recommend having new diff and knuckle seals just in case.
Sounds like quite the project man. Good luck.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 12-11-2022, 10:11 AM #7
found the diff seal on rockauto but didn't know what the knuckle one was called, thank you didn't even think of seals when pulling the axle out, gonna refresh all the fluids at the same time as well. so i have alot of work to do, most likely i'll start after xmas eve, we have a family gathering and don't want half the truck in the driveway and garage. but i'm just purchasing the parts needed and piling them in the room. i would just rather get this all done in one shot than have to replace stuff down the road i was already messing with. plus i've replaced every part i have laid my hands on since i have had this 4runner so i plan to continue the process.
ball , bushings , front , moog , suspension
Still squeaking after suspension refresh Toystory2 4th Gen T4Rs 20 09-22-2021 06:06 PM
Suspension refresh kit? dcTR4 4th Gen T4Rs 6 11-28-2018 02:22 PM
Best value suspension refresh for on road use? TFin04 3rd gen T4Rs 21 06-30-2018 05:00 PM
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
Front suspension refresh radlynx 4th Gen T4Rs 2 03-03-2017 04:20 PM
