Old 12-09-2022, 12:28 AM #1
TannerW's Avatar
TannerW TannerW is offline
Real Name: Tanner
TannerW is on a distinguished road
TannerW's Avatar
Real Name: Tanner
Air Condition Problems
I wanted to post some symptoms of my air condition to see if anyone may know what the problem is. When the AC is on the highest fan setting it feels like it is blowing heat. A few months ago I did an AC recharge which seemed to help but when trying this time the digital gauge read 0 psi and would not increase. Is there anything I should check to see what may be going on?
Thanks!
1996 V6 SR5 260k
2006 V6 SR5 150k
TannerW is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 08:52 AM #2
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
Thanks!
they make a dye that you can inject into the system, theirs one that has the adaptor already on the can. drive around for a day or two. i picked up a UV light on amazon for $6. i eneded up putting a new unit in mine, bought the vaccum tool to get all the air out and recharged the line, has been fantastic every since.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 11:37 AM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
If the gas pressure drops enough the compressor won't engage. You must have a leak somewhere.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 12:59 PM #4
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Thanks!
If you are adding refrigerant and pressure is not increasing, you have a big leak. Adding dye is the right answer and then look for the leak...should be readily apparent. Make sure you check the evaporator drain hose on the firewall.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 12-11-2022, 10:17 AM #5
after i found the leak, i replaced the condensor which came with a dryer, vaccummed the system and turned it on. my compressor would go no higher than 80 and than drop, i tried refilling refrigerant and no luck, still dropped pressure. bought a new compressor, redid the work, vaccum, refilled to spec, and bam has been great ever since.
air , condition , digital , gauge , time
New truck, new problems vent problems. COhailtr4 4th Gen T4Rs 2 10-08-2022 09:58 AM
U-joints Condition FrogginAround 3rd gen T4Rs 9 03-15-2020 04:33 PM
Installing a new air condition kit Bdazzla Classic T4Rs 2 12-19-2012 11:08 AM
o2 sensor problems and alignment problems jjlemus1 Classic T4Rs 34 06-01-2011 02:35 PM
New car condition please help! Plasmablade 5th gen T4Rs 19 04-28-2010 01:50 AM
