Old 12-28-2022, 07:04 PM #31
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Originally Posted by chrisbagnell View Post
Yea I am staying away from rebuilt engines, mine is running great minus the small leak. I am going to drive it tonight and see how its running. Taking to shop tomorrow!
I appreciate your input. I am sure the mechanic was just trying to tell me every possible way it could go wrong, however I think this will be a very easy job from their perspective. Never had a check engine light, no overheating, etc.
Right after I posted this I called one more shop and they quoted me about $4400 according to their engine tech give or take a little. I am going to take it in tomorrow and see if I provide my own parts if it will be cheaper and mention the timing chain not having to be done. I think its preventative maintenance from their perspective and makes sense since it already had to come off, but I will update with what they say. If I can get this all done for under $5,000 I will be one happy camper!
Believe me, I totally get the preventative maintenance idea. I’m a big fan of it myself. I just don’t know how one can choose to replace just the main timing chain over all of the other components there unless it is out of spec per the service manual. There are 3 chains, 4 chain guides, 3 tensioners and two sprockets. All of the components, if replaced with OEM, will cost anywhere between $600 and $1000 depending on where they are bought. Going aftermarket with working timing components doesn’t make sense to me. If your goal is to keep the total cost down, then keep that in mind since the labor costs are the biggest part of this job. My opinion of course.
It sounds like you are on the right track though. Keep us posted…
zguy1 is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 12:16 PM #32
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
Got the call this morning from the shop I dropped my truck off at, expecting it to be confirmation on headgasket and estimated bill. They told me they spent the past few days diagnosing, did a full leakdown test as well as stuck a camera down the cylinder heads and found no signs of headgasket issue. From the call it seemed like they examined every possible option on the engine and wanted to confirm how I suspected it in the first place since they could not find anything relating to headgasket issues.
They did find a very small leak in the radiator and the thermostat is stuck in one position, but the engine never overheated and they are going to replaced thermostat and radiator. This would explain the coolant loss...
However, I am confused as to why coolant was appearing in the oil analysis from blackstone. Still a bit concerned on this one. I did tell the Toyota dealership I suspected a headgasket leak, so I am wondering if they gave it a bad diagnoses to collect a paycheck.
2004 Sport Edition v6 4wd, 180k+ miles
My Build Thread: CBR's Build Thread
My Write-ups: How to Manually Release Rear Hatch with Pictures
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 01:56 PM #33
jambone jambone is offline
jambone is on a distinguished road
Well that is fantastic news!
I was about to reply to this thread saying that (if I were in your shoes) I would repair that engine rather than swap in a used one. You know the history of yours, and all is well, minus the faulty head gasket issue. If you feel like driving it for another 10 years, then I wouldn't hesitate to have it fixed. Just find the right shop at a reasonable price (not necessarily the cheapest). ~$5k is a lot to drop, but it's cheaper than a new (or new/used) car.
2006 4Runner SR5 4WD, V8
jambone is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 02:19 PM #34
zguy1's Avatar
zguy1's Avatar
That is good news for sure. My radiator was leaking but was not visible until I removed the shroud to take a better look. I wish I could comment on the Blackstone analysis, but I never did one. I'm sure others may chime in.
Personally, I wouldn't worry about the Blackstone report especially if it wasn't obvious when visually checking the oil after an oil change. I would fix the radiator and thermostat and call it a day. Just my opinion of course...
Old 01-03-2023, 11:36 PM #35
hutchison hutchison is offline
hutchison is on a distinguished road
Talking
Dang 5.7k for hg's!
Is this back the future 4 in 2032?
I would always reccomend learning by way of toyota build book and or haynes manual an engine stand and crane and some patience in your own time. This takes weeks or months for home build. Also comes with its own quality and cleanliness risks for the amateur, but i would never advise against learning.
I have built 4 previous toyota variants of engine, 3 on the bench and one in the vehicle, F doing one in the vehicle again, But at 5.7k i'm sold on that idea.
hutchison is offline   Reply With QuoteReply With Quote
Old 07-21-2024, 08:54 PM #36
gearheadengineer gearheadengineer is offline
gearheadengineer is on a distinguished road
Originally Posted by rumfoord View Post
Had mine done by an independent shop for around $3500 Canadian. Heads machined and all. Just a note mine wasn't discovered until I started getting rough idles on start and blowing white smoke out exhaust. If you aren't experiencing those yet you're probably fine for a little bit. No regret having done and bought me 6 years so far.
Are you able to name drop said shop?? I’m in Canada too and frequent go across the country. Would definitely be willing to stop somewhere for a couple days for that price.
gearheadengineer is offline   Reply With QuoteReply With Quote
4runner , engine , headgasket , tested , told
2004 4.0L - Headgasket Change now P0020/P0010/P0018 jcbrown630 4th Gen T4Rs 4 10-29-2020 04:16 PM
2004 v6 reliability after headgasket repair? dcTR4 4th Gen T4Rs 6 11-22-2018 11:00 AM
Quoted $1500 for front Bearings 2004 4Runner Sheaman 4th Gen T4Rs 7 12-21-2014 11:47 PM
Been Quoted with TE price damian.ma 5th gen T4Rs 6 04-08-2010 01:02 AM
Price quoted for a 4WD SR5 tjrlcr2k1 5th gen T4Rs 10 03-04-2010 11:16 PM
