04-30-2016, 01:23 AM
Which new rear springs?
I have already swapped in front suspension from a Tacoma in my 2003 V8 4runner, and now I'm looking at the rear. I was initially thinking about new factory FJ springs, but I dont think I would get the lift I'm looking for. I'd like the following improvements out of the new springs, and was hoping you all could recommend a set:
Good ride quality
Enough extra load carrying capacity to compensate for camping gear and a heavy drawer system
Approximately an inch or two of lift over stock
Thanks for the help.
04-30-2016, 10:57 AM
I have the same dilemma. Not doing it any time soon but I am going with the ICON 2" spring.
04-30-2016, 11:01 AM
5th gen rears?
from what ive read they yield about 1 to 1.5" lift
05-02-2016, 01:39 PM
That's an interesting option--I hadn't read that. I'll do a little research here on that idea, thanks.
I'm leaning towards the 2" Toytec springs.
If I understand correctly, the TRD Tacoma shocks (with the appropriate bushing) that I have will work in the back, even with an inch or two of lift. They are nearly new, so it seems a shame to waste them. So I think I'm good on shocks.
05-02-2016, 01:42 PM
the best rear spring hands down is the metaltech Springs. make the toytecs look like an amatuer atempt. handle all the crap i carry with ease, rides 10x better than my old toytec and OME 885 or 895s i cant remember what the rear # is. LTDSC will say the same thing. the medium one yield ~2" of lift and the heavys ~3", unloaded. loaded its 1.5 and 2-2.5" depending on what the load is.
2004 white Limited v8 NOW WITH 35s Build Thread -toytec BOSS front set at 1.5" with 2" spacer and Metaltech LT rear -1" 4crawler BL. -Nitro 4.56 gears. -35x12.50r17 treadwright Guarddog MTs. -swaybars removed. -Ebay uniball UCAs. -RCI skids. -E-locker retrofit with 12voltguy panel and harness. -Shrockworks sliders. - body damage and the such
1989 DLX 4runner SAS BUILD
05-02-2016, 03:59 PM
I don't see any actual 'MetalTech' brand springs on their site--are you referring to the Icon springs?
Also, does anyone know if the factory Tacoma TRD rear shocks I picked will be sufficiently long enough for mild wheeling with the 2" longer springs?
Thanks
05-02-2016, 04:15 PM
Are you referring to their dual rate coil?
White 2017 TRD Pro
Black 2007 Limited V6 4WD - Sold
05-02-2016, 04:29 PM
Real Name: Alex
Real Name: Alex
Thanks
He's referring to the progressive (dual rate) coil spring they offer with their LT rear kits.
MT-GSJ-4052 is the part number.
Link to springs
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
05-02-2016, 06:01 PM
Wheelers T12 spring is made by Eibach, from a production standpoint they make great springs, I think 1.5" lift, seems like a good option for me.
05-02-2016, 06:25 PM
In our opinion here at the shop from the rigs weve built and ridden in, this is how they rank in ride quality from best to just okay.
Metaltech LT Springs, ICON 2.0, SAW (not available at the moment), ARB/OME, Toytec.
05-02-2016, 07:24 PM
And what shocks do you usually pair with? Billies?
Looking at doing an upgrade all-around as well, looking at something different beside the standard FJ-springs-with-Billies.
Current: 2015 TRD Pro | Inferno Orange | C4Fab sliders | SSO Slimline bumper | WARN Zeon 10S winch | Bushwacker flares
Sold: 2006 4Runner Limited | Galactic Gray
05-02-2016, 07:26 PM
Is this off road only or street queens too?
05-02-2016, 07:52 PM
Mostly ICONs, and lot of ICON 2.0 springs with Bil 5160 shocks. The MetalTech LT springs need a specific shock from ICON that is slightly longer. We also do a fair amount of Fox 2.0 with them.
05-02-2016, 07:59 PM
Real Name: Danny
Real Name: Danny
I'll second the Metal Tech Springs. I'm running them with the extended 2.0 Icon Remote Reservoir shocks and have LOVED them compared to the Toytec springs I had on before. On and Off Road.
