01-01-2023, 03:08 PM
Roof Leak - 2004 SR5 drivers side
Hi All, happy new year. I could use some help finding the source of a roof leak on my 2004 SR5. The leak in on the drivers side. Water comes in from the sunglass compartment and the seat belt is wet. I do not have a sun roof and have a stock roof rack. The 1st spot I checked was the roof rack bolts. I removed all 8 bolts, cleaned out the channels, put silicone around the white tubes, on the bolts, and on the bottom of roof rack feet that make contact with the roof. I knew it was going to rain hard last night, so I put a towel over the center console and this morning the towel and drivers side seat is wet. Any advice where to look next? Thanks in advance.
01-01-2023, 06:12 PM
Have a friend use a garden hose outside while you look inside the vehicle. Do not use high pressure. Meaning no nozzle. Just straight out of the hose. Have the assistant cover one area a few minutes at a time. Recommend performing this at your normal parking spot.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
01-01-2023, 07:55 PM
Great idea! I believe that I found the problem area. The leak appears when I apply water on this circled location or behind the rack mount. Time to find new seals.
01-01-2023, 08:48 PM
Nice. Post back if you find/replace the seal, I'm thinking this is going to become more and more necessary. Although it's not leaking, my seals are buckling like yours on my 2008...
01-01-2023, 09:15 PM
I found it for my 2004. These pns may not be the same for other models. I am going to get 3 parts. Left, right, center reveal.
01-02-2023, 02:31 AM
Real Name: Skip
Real Name: Skip
I'm just guessing here..BUT those moldings aren't going to completely reseal where it's leaking, it may require some sealant under them to stop the leaking...But I could be wrong.
2004 Limited V8
01-05-2023, 08:05 AM
Real Name: John
Real Name: John
Also
Good find, you think the water is going underneath the windshield? if so the adheasive to the windshield may need to be looked at.
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
01-05-2023, 09:11 AM
Real Name: brian
Real Name: brian
Not too be over critical but clean your roof.and areas around it. If the painted areas look like that, under the moldings could be worse. The areas under that molding do not lead into the vehicle unless you have rot or missing, dried out urethane. Also unless you park on an in cline with the back end facing down that area would leak on the dash not the console or seat belt. Remember water follows the path of least resistance.
I've had those moldings off many times and there is nothing under there, it's just trim. If you are leaking that high and in that area, my guess is under the roof rack rail moldings is dirty and it's blocking a path for water to flow and its backing up somewhere. Also take out the silicone and use Strip Caulk by 3m or some equivalent product. Strip caulk is what Toyota used. Silicone was not made to be used in that area and there could be a pinhole somewhere in the silicone.
I took my roof rack off to put on a Sport rack and under the moldings was beyond filthy.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, General Grabber ATX 275 55 20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
01-05-2023, 10:14 AM
I had a windshield person take a look at it and those moldings on the outside of the windshield are not a water seal, they are cosmetic. There is urethane/sealant that goes around the windshield that I cannot see. There may be frame rust under the windshield. There may be a break in the sealant adhesive where it was not seamed properly. Only way to determine that is to remove the windshield which may crack when they do that. I did notice that under the roof rack was very dirty. I cleaned under the mounts but could do better elsewhere. I may take the rack off completely and put the plugs in.
01-06-2023, 12:13 AM
Please keep us posted. I have the same problem after heavy rainfall. A lot of water coming through the dome light and into the center console/shifter.
01-06-2023, 05:37 PM
With sun/moonroof equipped vehicles, it's always a good idea to check the drain tubes for the moonroof area. I think most of the time manufacturers will run them down next to the windshield. I'm pretty sure that's how these roof systems drain out but I'm not sure how far down they go. I believe if you look at the forward part with the moonroof open (slid back), you should see one on each side of the front plastic under where the roof would be
I think if you're getting water in the roof center compartment, it might in part have something to do with this.
2005 SR5 V6 4x4
Bilstein 5100's @ .85"
01-06-2023, 07:21 PM
Real Name: Skip
Real Name: Skip
Just an FYI, you apparently didn't read this entire topic, or at least the first post by the OP, if you had you would know he stated he didn't have a sun/moon roof, so therefore his issue can't be the drain tubes.
2004 Limited V8
01-07-2023, 11:47 AM
Yep, no sun/moon roof. I took the roof rack off, cleaned the channels, resealed the bolts. Still getting water in. Drivers side seat belt, left corner of sunglass holder, and now this passenger side wall. The SUV smells like a musty, damp basement!
The windshield is the next thing to look at. The windshield shop quoted me $240 to remove and replace but there is a chance of cracking it. It was ~$300 to replace so I am just going to do that. They said if there is too much rust/metal damage they cannot put the windshield back in due to safety. If it comes to that a body shop would have to repair it and plus new might just say screw it. I know I have about $2k worth of other repairs, plus tires & brakes needed. I would be putting in more than it's worth. Might be time for a used TRD premium
I get the windshield replaced Monday and will reply back the findings. Thanks all!
01-09-2023, 05:48 PM
Pretty sure we found the root cause for my leaks....crapping adhesive sealing on the window replace many years ago. As soon as he pulled the urethane out he could see rust at the top. When he got the windshield out there was no adhesive sticking to the top edge like there was at the bottom. Thankfully no rust holes in the frame. The technician cleaned the rust, applied primer, and put in a new (hopefully properly sealed) windshield for $328 (glass/labor/tax).
It's supposed to rain tomorrow. We shall see how it goes. Thanks for all the replies.
Top edge frame rust under urethane
Piece of old urethane, rust stuck to it
Top inside glass, no adhesive
Bottom inside glass, adhesive stuck
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
