Member
Real Name: brian
Member
Real Name: brian
Not too be over critical but clean your roof.and areas around it. If the painted areas look like that, under the moldings could be worse. The areas under that molding do not lead into the vehicle unless you have rot or missing, dried out urethane. Also unless you park on an in cline with the back end facing down that area would leak on the dash not the console or seat belt. Remember water follows the path of least resistance.
I've had those moldings off many times and there is nothing under there, it's just trim. If you are leaking that high and in that area, my guess is under the roof rack rail moldings is dirty and it's blocking a path for water to flow and its backing up somewhere. Also take out the silicone and use Strip Caulk by 3m or some equivalent product. Strip caulk is what Toyota used. Silicone was not made to be used in that area and there could be a pinhole somewhere in the silicone.
I took my roof rack off to put on a Sport rack and under the moldings was beyond filthy.
__________________
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
