12-09-2022, 05:31 PM
Real Name: Chris
Real Name: Chris
Stealership just quoted me $7,000 for headgasket on 2004
I dropped off my 2004 4Runner to the dealership this morning to get tested for a headgasket issue. Told them I have been getting the oil tested and it shows coolant in it but no other signs of any issues (smoke, loss of power, etc). They seemed skeptical of my information and told me they would test the cylinders.
Just got off the phone with them and the guy told me cylinder 4 is leaking and its a very expensive job. They would have to pull the motor out of the vehicle... and used a lot of terms to make it sound sophisticated "we will have to take it down to the heads which is EXTREMELY difficult etc "... Also told me I am at extreme risk driving it because of how bad it is...
hmmmm I don't buy it. I was expecting around $2-4k total, did not expect them to say the engine needs to come out. At that price its cheaper to source a used engine. I have never seen a headgasket repair on a 4Runner that requires the engine to come out....
Would be nice to hear the forums opinions/thoughts.
Located in Langhorne, PA
2004 Sport Edition v6 4wd, 180k+ miles
My Build Thread: CBR's Build Thread
My Write-ups: How to Manually Release Rear Hatch with Pictures
12-09-2022, 05:52 PM
That's comical and would be the last time I went to that dealer.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
12-09-2022, 06:00 PM
"Your vehicle warranty is about to expire"
Sent from my SM-S908U using Tapatalk
12-09-2022, 06:54 PM
I'm doing the head gasket on my 08 as I type. $7000 is ridiculous but I will say that $2000 is not realistic for anyone who does this for a living. This is a big job.
I asked around at several dealerships before taking this on myself and they were a bit hesitant to give me an estimate. They roughly stated that the cost would be upwards of $3500. Keep in mind that is only replacing the head gasket and re-sealing the motor.
What about any cylinder head work?
Do you want them to check the heads or clean and reinstall with new head gaskets?
If they check the heads and find leaks, are you going to decide to do a valve job?
I honestly don't know if I can blame the dealership for a vague estimate especially if the history of car is unknown and has higher miles. With cost aside, several of the mechanics really thought going with a used or new short block made more sense especially if you want to keep the truck.
12-09-2022, 10:02 PM
Just because it’s possible to pull heads with the motor still in doesn’t mean that’s the easy way to do it. If I had the resources (lift, shop space, etc) I would be pulling the motor for anything more than a valve cover job.
There’s a lot that can go wrong and make it for a shity job working in the engine bay so I don’t question that one bit. The $7k seems steep but I’m curious to know what parts they wrote into that estimate. Even at a shop rate they charge that seems to be hefty just for labor.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
12-09-2022, 10:54 PM
Had mine done by an independent shop for around $3500 Canadian. Heads machined and all. Just a note mine wasn't discovered until I started getting rough idles on start and blowing white smoke out exhaust. If you aren't experiencing those yet you're probably fine for a little bit. No regret having done and bought me 6 years so far.
12-11-2022, 05:59 AM
How many miles are you at?
Silver 05’ 4Runner V8 4.7L Sport, Bilstein 5100 shocks, Dobinsons C59-314B front springs, Dobinsons Aluminum Billet UCA’s, Superpro offset LCA’s, OCD sway bar endlinks, Toytec Superflex RCC2.0-P rear springs, Cooper Discoverer A/T 3 285/70/17 tires, SCS Blaze 10 Wheels with -10mm offset, and lots of plans for future mods…
12-13-2022, 04:13 PM
Real Name: Chris
Real Name: Chris
I will post the estimate below, but thanks for your input. If there are leaks and I need a valve job I will have to re-evaluate it all. I have already been searching for replacement engines and the prices are inflated a bit. How much did yours cost all in and did you need extra work?
Thanks for the confidence booster! I've parked it for now but still purrs like a kitten
181,000 miles
12-13-2022, 04:18 PM
Real Name: Chris
Real Name: Chris
Here is the estimate. Some of it seems to be just added maintenance. Timing chain makes sense while already in there. Now that I am looking at the image, I believe everything with and * is not needed.
12-13-2022, 05:45 PM
181,000 miles
Here are some more of my thoughts for what it's worth. I didn't finish the job yet but I am currently reassembling.
181,000 miles is pretty low. In my opinion, if your car ran fine, idled well, you probably don't need any cylinder head work.
To date, I have spent $1264 so far. That breaks down to the following:
$560.00 in parts.
- (Gaskets, water pump, thermostat, exhaust manifold studs, FIPG, spark plugs and head studs. All parts are Toyota except for the head studs)
$380.00 in machine shop services
- Pressure check, stud removal and resurfacing)
$79.00 in fluids (Oil, filter and antifreeze)
$200.00 in misc tools
$45.00 in cleaning supplies (Parts cleaner and paper towels)
7 of my valves were leaking but I opted to try and clean them up myself after the machine shop owner suggested I give it a try. We will see how good I did shortly.
I hope that helps...
12-13-2022, 06:22 PM
Real Name: Chris
Real Name: Chris
Thanks for the quick response. I have been thinking over this past weekend, and I have probably driven over 10k miles with this leak with no issues other than slow coolant loss. Ive been driving about 250 miles a week for the past couple of months with no issues whatsoever with the engine so hoping all valves are solid. Thank you for the cost breakdown too.
I'm relived the headgasket leak was finally found so I can move forward with repairs.
Anything else I should think about replacing while its apart? I saw a thread asking this exact question but was wondering if there were things overlooked
12-13-2022, 06:52 PM
I am no expert but have done most of the repairs and maintenance on my truck to date. Regarding timing components and what to replace if any seems to be a debatable topic. Your quote just lists the timing chain. Not sure why they just chose that. For me, I chose not replace any timing components. I may regret that choice but I guess we will see.
Everything below the water pump on the estimate seems like fluff. Aside from the idler pulleys, all of the those other services can be done at a later time as you are not saving anything on labor by combining them with this repair.
To answer your question, I don't think you are missing anything as far as what to consider replacing.
12-14-2022, 09:28 AM
I don't know what the timing chain service interval is on these, surely more than timing belts since chains are typically meant to last the life of the vehicle.. however...you are already doing just about all of the work to get the heads off, why not go the very extra little bit and throw in new timing components to be on the safe side? Not to mention that probably means you left the front main seal alone as well?
Replacing a water pump while doing a timing chain job at 181k miles is far from fluff. You'd be silly not to spend the extra $200 for a water pump while everything is already apart. I can't imagine finding a place to do a water pump replacement with parts and labor for $200..
12-14-2022, 09:37 AM
Are you set on having this place move forward with the repairs? Could be worth asking around other local shops to see what kind of estimate you come back with. Pulling the motor at a proper shop is far from an extensive "difficult" thing to do. It actually makes the rest of the work significantly quicker and easier than doing it in the vehicle.
anyhow, if you are set on getting the work done and the motor does come out of the car what I would recommend in place of the Transmission service, differential service, power steering service and hvac vent service (which are all very straight forward to do if you ever decided and not necessities in my mind, I would have them replace the front and rear main seals on the crankshaft.
Last thing I would want to happen is to spend all the time and money on this repair and come back to a leaking front main, or even worse, rear main seal 20k, 30k miles down the road.
12-14-2022, 09:56 AM
When I said "below the water pump on the estimate", I was referring to the other misc services. E.g., Transfer case and diff service, transmission service, HVAC vent service and power steering flush. These are the ones I meant by "fluff". That's almost $2k extra on top of the repair to actually fix his truck. Even if decided to get those done at the same dealer, he could always do those later.
I am not against changing the timing chain, I just meant that if you ask 10 people they will tell you ten different things about what timing components to replace.
