Old 02-10-2023, 11:12 PM #16
shahsmerdis shahsmerdis is offline
shahsmerdis is on a distinguished road
Originally Posted by 4RunnerAquasport View Post
When I responded a few weeks ago, I was actually researching a shift kit install at the time, so that's why I found those Repair manual pages I posted so quickly. My knowledge of transmissions is at a kindergarten level, so I'm really not qualified to advise anyone on which way to proceed.
There are way more knowledgeable people on here.
If @BlackWorksInc is still around, he may be able to point you in the right direction.
Sorry I'm not much help and good luck.
Unfortunately the transmission wiring harness is done! =[
When to call quits 04 V8, ~135k miles Med-Heavy Rust, Multiple issues-20230210_121511-jpg  When to call quits 04 V8, ~135k miles Med-Heavy Rust, Multiple issues-20230210_122911-jpg
2004 limited V8
2002 SR5 V6
shahsmerdis is offline   Reply With QuoteReply With Quote
Old 02-11-2023, 02:05 PM #17
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
OP, what state are you in?
Would you be interested in selling this for parts? Assume you’re in the rust belt somewhere.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 02-11-2023, 03:54 PM #18
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
His ID says "bronx", that's New York.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 02-11-2023, 10:52 PM #19
PeT4R PeT4R is offline
PeT4R is on a distinguished road
I know the transmission harness seems daunting but it really isn’t. Neither is dropping the pan. You are going to need a solenoid harness and Toyota replacement pins.
I used this page as a guide: Preventative Maintenance 2006 DC 4.7 A750E P0986 & P2716 Transmission Problem | Toyota Tundra Forums
If you can solder you can do this. I ended up depinning and splicing 3 wires. It’s possible you might need to do a couple more based on your image. Let me know if you need any clarifications or have questions. I did mine (v6) at 175 and it just hit 200k with no issue.
PeT4R is offline   Reply With QuoteReply With Quote
Old 04-15-2023, 08:35 PM #20
Just want to let every one know 4runner lives to see another day. it was brutal. cut the floor board cuz doing this on the floor with barely an access . it was hard enough to do it from above...
basically followed a few videos out there. I saw someones youtube video where you can cut the floor board.
transmission harness going to the ecu had so many wires that just snapped when you touched it.
so i just cut the wires bought new transmission harness on amazon, and but splice + heat shrink wire and wired it up
I use 23 pin nails from my nailing gun and drowned it fluid film and hoped it worked. if someone in the future is reading this, you can full set the pin in and just shy of flush snip it. should be more than enough to make up contact.
it takes several tries to get it right. . but eventually you will get no codes.
its also a mother lover to get disconnected the first time.
2004 limited V8
2002 SR5 V6
call , car , quits , rusted , thought
FS: '07 4th Gen 4Runner SR5 V8; 135k miles; Denver $9k TXtoCO For Sale: Vehicles 1 08-05-2021 09:42 AM
FS: 3rd Gen '02 4Runner SR5 V6 4WD, *No Rust* 141k Miles, has Issues. Hartford, CT GabrielMiguel For Sale: Vehicles 3 12-20-2019 07:09 PM
Should I call it quits, or hang in there? MPG4Runner 3rd gen T4Rs 38 09-11-2015 10:26 PM
New Potential Buyer! Help Me! 2004 V6 135k Issues RC86 New Members 1 03-14-2015 08:09 PM
When do you call it quits? nkadlac 3rd gen T4Rs 16 09-06-2013 06:14 AM
