Old 01-15-2023, 10:40 PM #1
bricew25 bricew25 is offline
bricew25 is on a distinguished road
Removing Spare with TPMS
Hello,
Just a quick question about swapping my spare with a new one that doesnt have a TPMS stem. When I remove my spare wheel, will the TPMS light come on because it won't register anymore?
Thanks,
bricew25 is offline   Reply With QuoteReply With Quote
Old 01-15-2023, 11:21 PM #2
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 will become famous soon enough zguy1 will become famous soon enough
zguy1's Avatar
Yes, it will.
I believe you can program it out of the TPMS system. When I added a new set of wheels, I had to "relearn" the new OEM sensors. When doing so, I believe the Autel TPMS tool I was using gave me the option to use all 5 sensors or just 4 sensors. I didn't try it with 4 but assuming that option was valid, you should be able to program it out of the system. Maybe someone else can confirm.
zguy1 is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 09:30 AM #3
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Originally Posted by zguy1 View Post
Yes, it will.
I have an Autel MaxiTPMS TS501 but it doesn't offer the option to only record & store four wheels. It prompts for five wheels.
waypoint is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 04:06 PM #4
dasx86 dasx86 is offline
dasx86 is on a distinguished road
I have an Autel TS508. You can proceed without a spare.
It will prompt you to scan all 4 corner wheels, then the fifth (spare.) When it prompts you scan the spare, just move 20ft+ away from the car, and trigger the scan. After some time, it will error out, and then allow you to proceed forward without the spare; to the OBD programming process.
I did the above to get my 4 new sensors programmed into the ECU. I do not have a spare on the truck currently, and I have no TPMS light.
2005 Limited V8 4x4
dasx86 is offline   Reply With QuoteReply With Quote
light , remove , removing , spare , tpms
285 spare, should I have TPMS installed? Dianna 5th gen T4Rs 9 01-03-2022 10:46 PM
Spare TPMS Question scionicboom 5th gen T4Rs 16 05-29-2020 11:56 AM
TPMS Sensor in Spare? DavidR1 5th gen T4Rs 11 08-21-2019 10:39 AM
TPMS (4th gen) - flat spare tire, no TPMS light pipspeak Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-17-2018 11:31 PM
SR5 Spare, no TPMS, right? blackie2 5th gen T4Rs 12 02-27-2017 06:11 PM
