Old 01-16-2023, 11:36 AM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
Edit: PSA - Per StopTech, Their SS Brake Lines Don't Fit Sport Editions
I bought a set of StopTech 950.44007 stainless braided hoses for the front brakes on my '07 SE and needed to find the p/n to order the rear set. I checked their website and was puzzled to find the product listing for both the front and rear sets specify the smaller 319mm rotor. I called StopTech and was told that's correct, those hose sets only work with the smaller rotors and they don't make a set for the Sport brakes.
I'm no brake expert but I suppose it could be the case since the distance from the hard line connection to the caliper might be a bit longer, at least in front. The Toyota p/ns, front and rear, are the same for all trim levels so maybe they made the hose a bit longer to fit both? If that's the case, wouldn't StopTech be smart enough to do the same?
Are there any SE owners running 950.44007? Were the hoses tough to fit and/or have you had any issues?
TIA for any insight.
EDIT: Ordered the PowerStop BH00172 kit for front and rear in the meantime. What a mess.
EDIT 19Jan23: TLDR - Went back and forth w/ Stoptech and they state that the fitment notes are direct from Toyota. About people running these hoses on SEs without issue, Stoptech says: "FYI, while they may 'fit' both versions of the vehicle. That does not take into account the increased travel/articulation, of the other brake systems. The hoses go through stringent DOT testing to ensure they meet all bend, flex, stretch, etc that may occur on the vehicles they are cataloged for use with. Using them on vehicles outside of those risks damage or failure of a hose, and possible injury. Which is why we recommended against it and catalog the way they are."
Your truck, your call, just want everyone to make an informed decision.
Last edited by Bluesky 07; 01-19-2023 at 09:03 AM. Reason: New info from manufacturer
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 01:03 PM #2
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about phatcheeks has a spectacular aura about
phatcheeks's Avatar
Im running the same hose on my Sport Edition. No issues since I installed them 2 years ago.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker. PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 03:27 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
I have an '03 LTD. that had the small rotors, converted to large rotors had to change the calipers and used StopTech 44007 lines and no problem. Hard line does not change.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 01-16-2023, 08:07 PM #4
dasx86 dasx86 is offline
dasx86 is on a distinguished road
Edit: Oops, answering a question that wasn't asked - OP is asking about the rears. Leaving information anyway...
I also used the Stop Tech 950.44007.
Ordered them here: Amazon.com: STOP TECH 95044007 : Automotive
The first time I ordered them, I received a mislabeled part - actually ended up with a Subaru WRX part, with a banjo connection on one of end of the line. Second order, no problems.
2005 Limited V8 4x4
dasx86 is offline   Reply With QuoteReply With Quote
Old 01-18-2023, 09:49 AM #5
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
been running the stoptech lines for years now. you cant go wrong with them.
i also think goodridge makes a good complete set.
crown performance also
im running some metaltech4x4 over the axle lines.
as far as the rear lines, one of them might be marked left, but should fit the right better, same goes for the right, its the bend that goes to the caliper, i wonder if they changed it?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK LTS pads F+R, Stoptech slotted rotors and stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-18-2023, 02:10 PM #6
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I put stoptech on all 4 corners. No issues.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 01-18-2023, 02:39 PM #7
Bluesky 07's Avatar
Bluesky 07's Avatar
@riceandpho and @Drcoffee - do you both have SEs?
All this sounds to me like Stoptech doesn't know their own product well enough to understand it works on all trim levels.
Old 01-18-2023, 02:42 PM #8
Drcoffee's Avatar
Drcoffee's Avatar
Yup sport edition ‘07. I dont know why they wouldnt fit. Its not like the calipers are mounted in a different location.
Old 01-18-2023, 05:08 PM #9
Bluesky 07's Avatar
Bluesky 07's Avatar
Agree. I may have to plead out to overthinking this one. I'll contact Stoptech and see if they change or remove the note on the product listing since it's costing them sales (well, one at least lol). That info re: fitting the 319mm rotors only doesn't appear on Amazon btw - it says they fit. Apparently Amazon's fit feature doesn't drill down to the point of trim levels.
Old 01-18-2023, 06:35 PM #10
Bluesky 07's Avatar
Bluesky 07's Avatar
Well, Stoptech says that Toyota says these SS lines only work with the 319mm rotors. This is from their admirably prompt response to my email:
For the 950.44007 and 950.44507 there are fitment notes, directly from Toyota on which 4Runners these stainless-steel hose kits will work on. I am attaching a link and screenshot, for reference. I used a 2009 Toyota 4 Runner as an example. You will see the notes highlighted in yellow.
Their screenshot was exactly the same as the one in my original post. I think this is a big misunderstanding and b/c my curiosity seldom allows me to let things like this go, I will contact Toyota and ask them. They’ll more than likely send a nice say-nothing boilerplate reply and we can all move on.
Old 01-18-2023, 10:34 PM #11
Drcoffee's Avatar
Drcoffee's Avatar
Buy them on amazon and if they dont fit, send them back.
Old 01-18-2023, 11:47 PM #12
Bluesky 07's Avatar
Bluesky 07's Avatar
I have the PowerStop set on the way and will decide once I see them.
Old 01-19-2023, 09:06 AM #13
Bluesky 07's Avatar
Bluesky 07's Avatar
Have to give Centric/Stoptech credit. They're very responsive. Here's the latest, after I reiterated that the hoses seem to fit both rotor sizes: "FYI, while they may 'fit' both versions of the vehicle. That does not take into account the increased travel/articulation, of the other brake systems. The hoses go through stringent DOT testing to ensure they meet all bend, flex, stretch, etc that may occur on the vehicles they are cataloged for use with. Using them on vehicles outside of those risks damage or failure of a hose, and possible injury. Which is why we recommended against it and catalog the way they are."
Your truck, your call, just want everyone to be aware so they can make informed decisions.
I have the PowerStop SS set on the way and will compare the length of the front hose to the Stoptech version. I suspect it will be identical but we'll see.
Old 01-19-2023, 09:54 AM #14
riceandpho's Avatar
riceandpho's Avatar
i have a 07 sport edition.
been running these for years. its going to fit fine. if you need longer ones for your suspension, get crown performance.
my suspension is bilstein 5100 at 0.85 and moog spring, its up only a little bit, my stoptech lines are fine. even if you did 1 inch longer, it wont make much of a difference, now the rears dont matter, sicne its part of the axel. the one you need to worry about is the over the axel from the frame of the truck. just get the metaltech 4x4 or crown performance, youll want atleast 2 inches if your really lifted up.
Old 01-19-2023, 10:01 AM #15
riceandpho's Avatar
riceandpho's Avatar
the x-reas suspension extend less than the standard suspension, these remember the stock sport edition is lowered than the base sr5 model.
fit , front , rear , set , stoptech
Installing StopTech Braided Steel Brake Lines BamaDrewski 3rd gen T4Rs 24 08-03-2020 11:25 PM
Hawk LTS + stoptech SS brake lines Ti-Ben 4th Gen T4Rs 0 04-29-2012 04:06 PM
FS: 95-2000 4Runner StopTech FR. & RR. SS Brake Lines Christopher W. For Sale: T4R Items 2 02-13-2012 01:10 PM
