Old 01-19-2023, 12:12 PM #1
Bolderboulder's Avatar
Bolderboulder Bolderboulder is offline
Bolderboulder is on a distinguished road
Are there LED equivalents for A/C control and clock bulbs?
I cannot locate a definitive answer as to whether or not there are LED equivalents to the following Toyota OEM bulbs that illuminate the clock and HVAC control knobs.
If there are, *please* let me know their part numbers/manufacturer, etc..
The Toyota OEM bulb part numbers are:
90010-09015
90010-09016
90010-09017
90010-09018
90010-09019
Thank you!
Bolderboulder is offline   Reply With QuoteReply With Quote
Old 01-21-2023, 01:17 AM #2
riceandpho's Avatar
riceandpho riceandpho is online now
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
neo3 and neo4 for the lcd.
superbrightleds.com
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is online now   Reply With QuoteReply With Quote
Old 01-23-2023, 06:33 PM #3
superbrightleds.com
Thanks.
What part of the old bulb should be measured to correlate to the correct LED equivalent (T3 4mm, 5mm, T4 4mm, etc..)? And the LEDs would be a direct replacement, not requiring soldering, right?
Old 01-23-2023, 08:49 PM #4
riceandpho's Avatar
riceandpho's Avatar
Originally Posted by Bolderboulder View Post
Thanks.
neo4 for the lcd part, neo3 is for the rest of the lighting, all your switches and such. if you need to for the switches not in the ac controls, you might want to use those base for the neo 3 replacement, some of them might be a little too long and you cant use those switches, all you need to do is unwind and carefully separate the led and resistor leads from the new base , back to old base. but everything else should be plug and play. lcd screen will require a 12volt mod, if you know the pos and neg, all you need to supply the pos 12v, just make sure you dont use both power from the mod and circuit board.
Old 01-24-2023, 08:55 AM #5
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I'm assuming those neo3 and neo4 bulbs come with needed resistors built in?
I did my dashboard LED conversion, best, cheapest and quickest LED conversion I've ever done.. so I wanted to do match the center console as well... after dicking around with it for a long, long time I ended up buying a new set of factory bulbs to put back in.
For 1, I found conflicting information about fitment of the bases. Some had to be modified as they were too wide, not a big deal, I was able to use (after modifying) the oem bases with led's in them to make it work. After all this work, what I found was that I had some ungodly hot spots. Doing some research it looks like it's something people just live with... I couldn't and went back to stock. So good luck, hopefully yours works out better
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 03:41 PM #6
I bought this package of OEM bulbs via Amazon a week ago because it seemed that locating LED equivalents was just too much trouble. Each new bulb fit fine except for the 90010-09017; the two bulbs that rear-illuminate the LCD clock. The rear of the bulb has a vertical hash and, once properly installed into its socket behind the clock, the bulb+base must be gently turned about 1/4 of the way so that the hash is vertical and aligned with the similar hash above that socket. My two new bulbs will not rotate enough for their hash mark to be vertical. Therefore, the bulb base's metal contacts do not touch the socket's metal contacts so....no electrical connection=no light. The seller (Toyota of South Miami) said there is nothing they can do because the bulbs are the correct part number for my 4Runner. I have tried forcing the bulb to rotate more, but the shape of the base prevents it from turning more. The package of these nine tiny bulbs was $50!
I don't understand why this has become such a problem, I just want a freakin' illuminated clock.
Are there LED equivalents for A/C control and clock bulbs?-20230120_141537-jpg  Are there LED equivalents for A/C control and clock bulbs?-20230121_130455-jpg  Are there LED equivalents for A/C control and clock bulbs?-20230121_130521-jpg
Old 01-25-2023, 07:01 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You haven't mentioned which model T4R you have, the Limited has a couple of different bulbs than the SR5 and Sport Edtion because of the dual zone AC controls.
The attached image shows both version of the control panel and which bulbs are needed for each model display panel so you can compare the part numbers to the ones you purchased.
Have you compared you old bulb housing to the new housing, you also may be able to remove the bulb from the new housing and put them in the old housing.
Are there LED equivalents for A/C control and clock bulbs?-4-runner-ac-control-jpg
2004 Limited V8
bulbs , clock , oem , part , toyota
LED replacements for clock & A/C control backlights? Bolderboulder 4th Gen T4Rs 2 01-15-2023 06:13 PM
Clock and MPG LCD and AC control leds don't light up when the headlights are on garrett1946 New Members 1 11-21-2021 03:26 PM
Clock and climate bulbs (4th gen) lsmo_guy 4th Gen T4Rs 4 02-24-2020 01:50 PM
Climate Control/Clock Backlighting mchestnut 4th Gen T4Rs 8 04-27-2015 12:47 PM
Bulbs for Clock spcavender 4th Gen T4Rs 10 01-09-2014 10:17 AM
