Old 01-19-2023, 05:41 PM #1
Ron_Mexico Ron_Mexico is offline
Ron_Mexico is on a distinguished road
Power Steering feeling Stiff
Not sure what’s going on but I had this happen to me last winter. When it got extremely cold I noticed when I turn the steering wheel it felt really stiff/hard to turn the wheel. Once spring/summer come up power steering felt fine. Now here we are in winter again and now my steering is very stiff again. I checked the power steering reservoir and it was just below the cold low level. I topped it up to cold top level. Adding the fluid didn’t improve anything. Any ideas on what’s going on here? Is this the start to costly repairs? Once when warm weather comes back the steering will probably go back to normal. I don’t see any leaks!!
Ron_Mexico is offline   Reply With QuoteReply With Quote
Old 01-19-2023, 05:51 PM #2
andynj andynj is offline
andynj is on a distinguished road
In case you already haven't checked make sure its ATF in there not power steering fluid.
andynj is offline   Reply With QuoteReply With Quote
Old 01-19-2023, 05:51 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
Is it stiff through the whole rotation or more notchy like easier in some spots? How is it with the wheels off the ground? The steering shaft U-joints on these lock up when they get old. It is a replaceable part if that is your issue. Ton's of threads on this and videos on YT.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-20-2023, 08:52 PM #4
It’s hard at first like it doesn’t want to go and then it turns easy. But then it’s the opposite turning the other way. Again hard at first and then easy. I should add that I recently had my alignment done when I put on new snow tires. I hope adding the ATF to top up the fluid didn’t mess anything, I have no idea what was in it previously. The cap says to put in dexron fluid. I picked up the ATF fluid from the Toyota dealership.
Old 01-28-2023, 11:26 AM #5
Just an update, my power steering feels fine now!! Like it magically fixed itself. It was the coldest day yet at -18 degrees Celsius. I figured the cold had something to do with the stiffness but regardless of the cold it feels fine now. I’m really confused with what to look for now once when the warm weather comes around to work on this truck!!
Old 01-28-2023, 01:20 PM #6
Miha125 Miha125 is offline
Miha125 is on a distinguished road
New member. I need to flush power steering fluid due to submersion so I appreciate this post.
Miha125 is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 08:26 AM #7
Damn, the stiffness is back and hasn’t been that cold lately (-5c). It feels more stiff than ever. Anyone here have this issue in the past? Is this a common problem?
Old 02-13-2023, 06:58 PM #8
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
How old is the PS fluid in there, in years and mileage? If it's the factory fluid on a 4th gen, it's way past time for a fluid change. Consider using power steering fluid rather than ATF Dexron III, based on this:
How to make your Toyota Last Over 300k Miles without Major Repairs - YouTube (skip to 13:37 for PS fluid comments)
My '07 has 276K miles on it, with PS flushes over the years I've tried Castrol MaxLife ATF, Valvoline Dex/Merc, and finally settled on LubeGard Synthetic Power Steering Fluid. The ATFs were fine, but it had a groaning sound on cold startups below approx 40deg F. Louder as it got colder.
After viewing the guy's video linked above and seeing reasonable evidence of his claimed experience and certifications, I flushed in the Lubegard fluid and the cold groan is gone.
waypoint is offline   Reply With QuoteReply With Quote
Old 02-15-2023, 10:41 PM #9
BOSMECH's Avatar
BOSMECH BOSMECH is offline
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
BOSMECH is on a distinguished road
BOSMECH's Avatar
Lube your steering shaft yoke and u-joints just use some WD-40 there are 2 u-joints and that should do it.
I have done it several times on my 03 and on my 05.
2003 SR5 V6 4WD Stock (totaled)
2005 Sport Edition SR5 V6 4WD
BOSMECH is offline   Reply With QuoteReply With Quote
Old 03-03-2023, 10:11 PM #10
Thank you so much for your reply, I did what you suggested and now my steering feels buttery smooth!! Cheers!!
Old 03-03-2023, 10:57 PM #11
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
This is just going to be temporary fix, you need to replace that intermidiate steering shaft.
2004 Limited V8
Old 03-23-2023, 06:51 PM #12
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
I'm in the process of learning that it could be your ball joints. Mine started out very gradual, sort of like "Hmm, the steering fluid must be cold...." Then noticing that after a turn, the wheel wouldn't return to center on its own. Now it's like I barely have power assist at all.
I jacked up both sides, and just on a whim squirted some oil into the ball joints, then ran the steering lock to lock a few times. It felt great for a day or two, then went back to where it was.
I've got an appointment to have both LCA's replaced on Monday... I've gotta be on someone else's borrowed time by now.
Montego Murph is offline   Reply With QuoteReply With Quote
cold , felt , power , steering , wheel
Replaced intermediate steering shaft, steering stiff again after 2 months twa318 4th Gen T4Rs 6 11-18-2022 10:44 PM
Cleaning Power Steering Screen + Cardone Magna-Pure Inline Power Steering Filters BamaDrewski 3rd gen T4Rs 1 03-23-2016 05:48 PM
Stiff Steering. BunchDub11 4th Gen T4Rs 6 12-01-2014 07:25 PM
Replace u-joint on steering linkage to fix stiff steering? sibanez 4th Gen T4Rs 2 09-30-2014 08:28 AM
Stiff Steering BigK75 4th Gen T4Rs 0 11-19-2009 11:33 AM
