04-24-2016, 03:16 PM
Help, blew 140 amp alternator fuse cuz I'm stipid
Was trying to wire up second battery and accidentally reversed connections. Blew fuses including the major 140 amp alternator fuse. All I could find was an old thread saying that you need to remove the top half of the junction box to get to a couple bolts holding the alternator fuse in but I can't figure out how to get the junction box apart. Engine starts but won't shift from park and dash lit up like Christmas tree. Hopefully just relaxing alt fuse fixes everything but any help is appreciated.....
04-24-2016, 03:35 PM
Real Name: Chris
Real Name: Chris
It's stipid to relax alt fuses!
Chris - '07 SR5
‘05 Limited - sold
04-24-2016, 03:51 PM
I suppose it would be inadvisable to solder the fuse?....
I got the junction box apart but I don't see any way to get the bolt that holds the fuse in from the inside.
04-24-2016, 04:17 PM
Real Name: Kyle
Real Name: Kyle
Hey man. You're not the first one to do it. I did it too... and so have other people.
Separating the fuse block is a nightmare. Toyota has a sweet SST for doing it, but we don't get that comfort! Here's the best image I could find:
IIRC, there are 3 or 4 tabs you need to somehow release, and pull on the top section of the block to separate it from the bottom section. I had another person helping me. Just keep messing with it, you'll get it to separate eventually.
2015 SR5 T4R :: ordering parts.
2004 V8 T4R :: just a bunch of crap off ebay bolted on to a rusty toyota. ( build thread.)
04-24-2016, 04:46 PM
Thanks man I got it apart, can't get to the fuse bolts though. Don't know how they got them in there. I soldered the fuse connection and it runs fine but sometimes MIL comes on and all the other lights are on- abs, trac, vsc, 4lo, even the ebrake. I went to pull codes and the reader isn't getting power from the OBDII, so I don't know what the fack is going on.
04-24-2016, 04:54 PM
Real Name: Kyle
Real Name: Kyle
No, you didn't get it apart. That's how you get to the nut holding the fuse in. The whole thing separates.
You soldered that fuse??? WTF? That's not a good idea...
It also sounds like you may have fried some stuff... Better hope you didn't accidentally hook those batteries up in series and make a 24v system.
04-24-2016, 05:13 PM
Yes, soldering clearly not advisable. Understood. What could I have fried that would cause: no radio, no hvac, no 12v power, lights on dash, no power to OBDII, shift linkage lock, no turn signals?
I've checked all fuses at least twice.
04-24-2016, 05:53 PM
I've gotten all 4 clips and can pull it out enough but how do you remove it completely, do you have to disconnect the wiring on the driver front side?
04-24-2016, 09:03 PM
Hope you get it figured out.
Sub'd.
I'm rooting for you man!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
04-24-2016, 09:39 PM
Soooo, I re-soldered the fusible link and it appears to have fixed all problems except my radio has no power. I don't think the soldering is as big a deal as it sounds, the fusible link seems to have 2 break points based on where it blew originally, I soldered that point so it leaves the other. It's a temporary fix anyway because.....the gawdamned fuse is impossible to find! I went to 4 auto parts stores and looked online and the best I could come up with was an old eBay listing. Guess it's off to the dealer this week.
Now I just gotta figure out the radio...
04-24-2016, 09:52 PM
Real Name: Kyle
Real Name: Kyle
When I blew mine, I found it at the first auto parts store I went to...
04-25-2016, 01:40 AM
The radio usually has a fuse on the back. You would have to remove the radio and check that the fuse has not blown. Before you do that, there is another fuse near the engine compartment or inside underneath the steering column.
04-25-2016, 09:08 AM
Thanks, the 2 radio fuses are in the engine compartment junction box, but those are both fine so I'll pull the radio and check. Thanks!
04-25-2016, 12:42 PM
This is mostly true of aftermarket units and some older radios. 4th gen radios do not have one on the unit.
04-25-2016, 12:44 PM
The soldering is unreliable best case scenario it works as intended, worst case it doesn't blow at the required 140amps fast enough and puts that current through the system.
