Old 01-30-2023, 11:14 AM #16
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
anytime someone asks "how hard is _____?" it is always relative... changing out CV axles to me is one of the most straightforward things I do on my rig (Primarily because I have them in and out so many damn times at this point..)
Condition of your rig also plays a major roll... some things that are a breeze on mine (no rust, original florida car) end up being a 3 hour bolt removal process on some norther rigs.
All in all, great advice in here... I definitely second replacing the seals.. I was lazy and left mine alone last time, quickly discovered a leak soon after, and guess what? Literally had to the job all over again 2 weeks later
Worst thing for me seems to be popping the axles/c-clips back in.. you need to make sure they are sitting on the top and not swung down and drooping, but even with that I have an axle that just doesn't want to pop in and since I'm lazy and do the work myself it becomes a crappy process of struggling to seat it properly without tearing the boots or the seals.
I'm not running the front sway bar so that for me is out of the way already, but literally the only bolts I remove when swapping axles are the 2 lower balljoint bracket bolts and the axle nut (obviously). I leave everything else in place and just manhandle (or use a floorjack) to raise the knuckle where it needs to be to get the axle out, and viola!
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 02:39 AM #17
ace4aday's Avatar
ace4aday ace4aday is offline
ace4aday is on a distinguished road
ace4aday's Avatar
I came across a video during my research that suggested using a bit of grease on the c-clips to keep them centered on the axles (not hanging) when inserting them into the diff. They swore it made them easier to seat. I'm planning to try it when the weather warms up a little and I can reboot.
2008 Sport V6 in Salsa Red
Ironman 4x4 Stage 2 FCP Lift (2.5"/2")
Vision Manx II Wheels
275-70-17 KO2 Tires
Victory 4x4 Blitz Front Bumper
ace4aday is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 12:20 PM #18
I did the grease, little grease, lots of grease, turned one way, then another, something about the one particular c clip would not seat. I mean after multiple attempts of trying I literally ended up having to file it down a bit to seat. Enough not to pop out, but yea.. no two repairs are the same lol .
Old 02-07-2023, 05:19 PM #19
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Grease isn't needed. It might help, but just hold the axle and orient the clip with the opening down. Yes, it's still a little oblong, but that protrusion is minimized (clip opening up causes gravity to pull the clip down and presents a greater obstacle for allowing it to seat in the correct location). I feel like the key to installing is controlled inward pressure. It's really easy if you tap it in with the axle itself. Yes, you're tapping it with the tripod bearings, but it's really not much impact. Very little, actually.
Holding the inward pressure allows you to maintain your progress. Striking with a hammer and drift causes to much shock and there's a rebound action that causes you to loose your progress. If you are striking and not supporting the outer joint, that weight, due to gravity, is working against you and wanting to pull the axle back out.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 09:30 AM #20
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
if anyone has troubling taking them out, i can confirm that 2" axle forks from amazon worked great. spent about an hr trying to get them out various pry bars and hammering a chisel and my hand. so found the axle forks got here in a day and a couple hammer taps later, boom she popped out.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 09:36 AM #21
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Can you share a link of what you are talking about? I would like to try a different method when I remove mine next time.
zguy1 is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 02:54 PM #22
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
I use these, makes quick work of the swap.
Amazon.com: ABN Axle Popper Kit - 2 Piece Inner CV Axle Removal Tool Set CV Popper Wedge and Shim Ball Joint Separator Tools : Automotive
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
RivMan is offline   Reply With QuoteReply With Quote
Old 02-10-2023, 09:25 AM #23
i used exactly these, cap taps and bam popped right out.
$100 , axles , front , left , warranty
replacing front axles - which seals should I replace? moodle 4th Gen T4Rs 4 08-04-2017 01:11 PM
Dealer says replace both front axles.. tombob55 4th Gen T4Rs 42 04-07-2017 12:14 PM
To replace C.V. axles or just reband? JLRSR5 4th Gen T4Rs 6 01-31-2017 10:42 PM
Time for CV axles - what else to replace? Carl Fisher 4th Gen T4Rs 20 09-13-2016 02:18 PM
Should I replace the CV Axles???? Jeff T 4th Gen T4Rs 6 12-10-2011 05:04 AM
