Old 01-24-2023, 02:45 PM #1
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Front camera on a 4th gen?
Hey Guys, I did a fairly exhaustive search on this but only came up with options for a 5th gen. Can anybody point me in the direction of a kit, or a writeup on adding a front camera to a 4th gen. I have a backup camera and if I recall correctly my Sony head unit only had one input for a camera. I'd really like to add the front camera but I'm a little nervous about trying in on my own. Don't want to damage the head unit or anything. Thank in advance for any ideas.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 05:33 PM #2
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
First thing is to confirm that your head unit only has one input. If so, that's probably a nonstarter unless some kind of splitter type deal can be bought or made. If it has two inputs, it should be pretty simple to do following any of the backup cam writeups on the forum (mine is linked in my sig). You're just going to the other end of the truck. ;-)
I haven't look into these that much but one thing that comes to mind is what turns the front camera on? Is it only through the head unit, or can you have an on-demand switch? Questions better minds than mine will need to answer.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 10:42 AM #3
aemravan aemravan is offline
aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future aemravan has a brilliant future
First question I have is what are your expectations for this application? What's the intended use?
Just from previous experience.. any aftermarket camera setup is kind of worthless compared to a factory setup.. it's cool to be able to see stuff, but depending on the viewing angle and position of the camera it's hard to rely on to, for instance, back up or pull up right up against something.
If you only have 1 camera input, that means you won't be able to set independent guide-lines on the screen overlay, which means you'd be relying on the look and feel for distance vs where you bumper actually is.
With that out of the way, nothing is impossible.. I'm not electric engineer, but even with a single camera input it's possible to feed in more than 1 camera. You can either wire all this stuff yourself, or just buy a dedicated chinese camera splitter from amazon (something like this Amazon.com: Anytime Backup Camera, Video Switcher, Intelligent Multi-Function 4-Way Video Switcher (4 in, 1 Out) for Cars, Trucks, RVs : Electronics)
That may be overkill for what you need... ultimately the way the headunit/backup camera works is when you throw your car in reverse, a voltage signal is sent to power on the camera, once it's powered on, the signal from the camera triggers the headunit to overlay the camera feed.
This means that really all you have to do in order to have any of the cameras show up on your screen is power them on to have the signal sent. The complication with a single input is that you need to make sure you're only powering 1 camera at a time. More than likely what you'll want is an on-demand switch to kick on the front camera, which also simultaneously cuts off the power (or signal) circuit from the rear camera (meaning that even if you're in reverse and your rear camera is automatically on, hitting the button will kill that power and switch it over to the front camera).
I'm pretty sure all of this can be done via a simple toggle switch and relay setup, but a diagram is not something I can readily provide.. now that I got to the bottom of typing all this out I'm thinking maybe that controller/splitter I linked maybe the best option if your wiring knowledge is limited..
2003 Limited V8 4runner - Tacoma Front End Swap - Icon 2.5 front coilovers - Dobinsons IMS59-50575 LT Shocks w/ C59-749V springs - Coastal Off-Road Bumpers - ARB Front/Rear Lockers - 4.56 Gears - RCV front axles - Twin-stick FJ T-case swap - LC200 Steering Rack Swap
aemravan is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 02:08 PM #4
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I have a front camera using a kenwood excelon head unit and its absolutely useless. Don't waste your time. The lighting is horrible, the sunsets don't work, and night wheeling is a no go.
I can't see any reason to ever put one on again. I'm using a kenwood camera front and rear and kenwood dash cam. The dash cam and rear camera are great. Front useless after having it on the truck for 2 years.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 02:09 PM #5
^ Great feedback from someone actually using one. Kind of confirms the reason I never decided to run a front camera (especially a non-factory one)
Old 01-27-2023, 06:38 PM #6
MikeinNH67's Avatar
MikeinNH67 is just really nice MikeinNH67 is just really nice MikeinNH67 is just really nice MikeinNH67 is just really nice
MikeinNH67's Avatar
My aftermarket backup cam setup has two inputs. I added a camera to the front for plow attaching, it goes on with a toggle switch. Only issue on my setup is that the front camera is a mirror image of what it should be. Some units can flip the image but I don't see the option on mine. Left is right and right is left confusing.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-28-2023, 01:13 PM #7
Miha125 Miha125 is offline
Miha125 is on a distinguished road
New member. Same interest.
Miha125 is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 12:29 PM #8
Mikein,
I have the same issue with my front camera. It is mirrored and both Kenwood and crutchfield could not help me. The irony is the kenwood head unit recommended the kenwood cam!
I am thinking of putting the front cam under the truck facing back at my front diff so I can tell if I get hanged up on something.
Find some way to actually use it...
Old 02-01-2023, 05:55 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
Originally Posted by randy88fj62 View Post
Mikein,
Cool idea. I do see Amazon now has some cameras that you can cut a wire to make it mirror. Price is cheap enough to try for just the camera.
Mike
03 4runner Limited
Old 02-02-2023, 06:48 PM #10
TXST8SR5 TXST8SR5 is offline
TXST8SR5 is on a distinguished road
interesting thread. we are about to install a new h/u in my son's '06 and have a backup camera for it, but the unit has the capability of running a front camera. was wondering what peopl were doing to activate it.
my wife's caddy has a front camera that is activated by proximity, but obviously the '06 does not have that.
TXST8SR5 is offline   Reply With QuoteReply With Quote
camera , front , gen , head , unit
Anytime Backup Camera/Front Camera Group Buy ***CLOSED*** bRYANT619 Group Buys 161 06-05-2021 07:36 PM
Backup Camera Relocate & Wireless Wifi Front Camera dahorst 5th gen T4Rs 14 03-27-2021 02:51 PM
Anytime Backup Camera and Front Camera - February 2017 Group Buy bjohnston115 Group Buys 101 05-06-2020 11:39 AM
