Old 01-26-2023, 04:43 AM #1
4runherpow 4runherpow is offline
4runherpow is on a distinguished road
Installed o2 spacer, now less power?
I hadn’t gotten a response to my other thread so figured I’d directly address this question.
I installed the anti fouler fix for my P0420 code. I used the two foulers stacked on top of one another as recommended by many.
My CEL has stayed off (for now) but I have a noticeable loss of low end torque. It’s not huge but I definitely have to push the pedal further to get and maintain power.
I’ve been told the down stream does not affect fuel trim and air/fuel. But read somewhere else it can account for some fuel managment.
Anyone else hAve this experience? Is is because maybe the o2 sensor is spaced to far? I don’t want to run lean or damage my engine.
Thanks
4runherpow is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 06:54 AM #2
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
i'm no expert but o2 spacers shouldn't cause any engine performance whatsover, in fact the main reason you run them is to trick the ecu that everythings fine in case you are having cat converter issues, running headers among other reasons.
Did you erase the codes after installing the spacer? I'd say make sure your o2 sensors in general are ok and disconnect the battery for a few minutes.
Could be a relearning process for the ecu but I highly doubt it.
Looks a lot like a clogged cat issue tho.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 07:54 AM #3
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Agreed. Doubt that the foulers are causing this.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 07:06 PM #4
@miller507
This is what I thought but I’ve read somewhere that the smaller range of voltage that the downstream maintains can affect the feedback loop that the ecu uses to set afr at different throttle positions. Any other insights would be great. It’s like the first .5-.75” of the gas pedal is totally dead.
The only other thing I’ll say is I had a mechanic replace the upstream sensor the other day in pursuit of curing the p0420. It didn’t work, the code came back and I didn’t notice anything performance related then. I noticed right after the fouler fix.
@importman
That’s what I thought. I guess the only way to check is to take the fouler out. I’m on a trip drove 500 miles to Vermont. Definitely noticed a difference on hills. It’s upshifting all the time. She never did that before. Ever.
Old 01-26-2023, 11:51 PM #5
Could it perhaps be since the flow is blocked to the sensor it’s changing the ECU parameters for throttle sensitivity? I tired unplugging the battery to reset. Immediately after doing that there seemed to be an improvement but it only lasted for maybe a couple of mins. Seems like the reset may of brought back factory settings but the ECU quickly relearned. It seems from a stand still to be mostly ok, it’s applying throttle while moving - I have to depress almost a full inch before I get throttle response. So annoying!
Someone’s got to know what’s going on. I have a sneaking suspicion that the downstream sensor does have something to do with AFR or sending back info to ecu on air flow to adjust throttle, etc.
Old 01-30-2023, 10:56 AM #6
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
unless you're throwing engine codes it's highly doubtful that any close-loop feedback from the downstream sensor is causing what you're experiencing.
When you say you had the mechanic change the up-stream sensor while working on curing this issue originally.... is that replacement sensor still in there..?
ps: Like I mentioned in the other thread.. I've been running this work-around for over the past year with no CEL or change in throttle/performance, etc. This being a very common solution would probably have resulted in regular feedback from other if this was related to the downstream o2 sensor spacing... just my thought..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 05:52 PM #7
Marvin_Rall's Avatar
Marvin_Rall Marvin_Rall is offline
Real Name: Marvin S. Rall
Marvin_Rall is on a distinguished road
Installing anti-fouler fixes to correct a P0420 code can have unintended consequences, such as the loss of low-end torque that you have experienced. The down-stream oxygen (O2) sensor can have an impact on fuel management and air/fuel ratios, which could contribute to the loss of power. It's possible that the O2 sensor is now spaced too far away due to the anti-fouler fix, which could be affecting its readings. I would recommend having a professional diagnose the issue and determine the best course of action to avoid any potential damage to your engine.
Marvin_Rall is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 11:35 PM #8
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
I would install the torque app and record the B1S1 , B1S2, B2S1 & B2S2 voltages as well STFT & LTFT graphs vs trying to web guess the solution.
Sent from my SM-G981U1 using Tapatalk
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 09:48 AM #9
Old 02-01-2023, 01:23 PM #10
mcbru mcbru is offline
mcbru is on a distinguished road
Take the spacers off and see if the throttle performance returns.
If it doesn't you likely actually do have a clogged cat.
2005 V8 Limited 4wd - "Bruce"
Also: 2020 Miata
mcbru is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 05:16 PM #11
That is an excellent advice and easy to do. P0420 often gets a bad rap for "shooting the messenger" when the cats are indeed clogging up. But, the O2 sensors get the blame!
Cats are easy to clean with some muriatic acid and hot water. Just do a search on YT on the process. Clean your cats, save a ton of $$$$!!!
Old 02-01-2023, 11:52 PM #12
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
Originally Posted by aemravan View Post
I was thinking the same thing
Ida4runner is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 06:25 PM #13
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
You're an idiot and a shithead link spammer. That's not how any of this works.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
affect , fuel , installed , power , stream
Daystar 2.5/1.5 Spacer Installed honda_nos 4th Gen T4Rs 11 12-04-2011 09:00 PM
Installed Daystar 2.5 Front Spacer rwilliams 4th Gen T4Rs 6 09-25-2010 08:11 PM
Just Installed 2" Topout Spacer dylanc 4th Gen T4Rs 14 01-05-2009 05:50 PM
