Old 01-30-2023, 09:45 PM #1
gloch gloch is offline
gloch is on a distinguished road
Fox 2.0 installation issue
I am installing Fox 2.0s on my 03 V8 and I found that the rear shocks won't slide onto the bottom pin. I doublechecked the model number on the shock to make sure they are a match for the truck. Is this normal for Fox?
-mx
gloch is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 12:42 AM #2
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
What do you mean won't slide onto bottom pin?
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 01:53 AM #3
This is as far as I could slide the bottom of the shock onto the mount
Fox 2.0 installation issue-image_16843265-jpg  Fox 2.0 installation issue-image_67176705-jpg
Old 01-31-2023, 04:14 AM #4
I'm gonna ask the obvious question, did you try hitting it with a mallet??
07 SR5 4x4
Old 01-31-2023, 11:01 AM #5
Ha ha. Yep. That resulted in the photos above. Stuck part of the way on.
Old 01-31-2023, 11:17 AM #6
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
-mx
"If at first you don't succeed... smack it with a hammer!"
- 4runner proverb
Worked for me on my `05
Fox 2.0 installation issue-thumbnail_69212757902__950ea63e-f279-412e-8011-067dbaa6cada-jpg  Fox 2.0 installation issue-thumbnail_69212759050__e9b0d71b-ecd7-46e7-8ed9-b12dae8d61bc-jpg
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 11:53 AM #7
Did you have to hit it with a hammer to get the rears on the bottom?
Old 01-31-2023, 12:28 PM #8
Tyla_T4R Tyla_T4R is offline
Tyla_T4R is on a distinguished road
Put grease on the pin and inside the bushing. The foxes are tight
Tyla_T4R is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 02:48 PM #9
Battle Born Offroad Battle Born Offroad is offline
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Put the bottom on first, compress the shock and let it extend into the top mount.
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 11:28 AM #10
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
plus 1 on the above suggestion...
an obvious thing to do before you go dry-hammering the shock onto the mount would be to remove the top and do a dry-fit with only the bottom to confirm everything is happy.
More than likely the issue you're having is the fact that the lower shock mount sit angled downward and when installing the top first it could be hard to get the angle to line up properly.
My IMS and Icon shocks both came "locked out" with a metal strap in the compressed position.. assuming the fox shocks did not? That helped to get everything seated down at the bottom first before pulling the strap off and letting it extend into the upper mount.
Another thing you can do is get a socket extension or small diameter pipe that will fit the lower mount so you can put some pressure on it downward to get the angle to align. It's obviously meant to be a pretty tight fit.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 06:53 PM #11
TXST8SR5 TXST8SR5 is offline
TXST8SR5 is on a distinguished road
You're fighting a bad angle. The bigger hammer bit is usually the solution, but if you go crazy with it at that angle, you will likely chew up the bushing.
White Lithium grease in a spray can is your friend once you disconnect the top and set the bottom first. Spray the stud and inside the bushing liberally. It will slide right on.
White Lithium grease is great because it does not attract dirt like conventional grease does.
TXST8SR5 is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 02:19 AM #12
Thanks for the ideas. I think I was dealing with the combination of Fox shocks being tight and 0 degrees temps in our area. I think the rubber shrank a bit. I got some silicone grease, a small sledge, and I kept the shocks inside for a day. They are now installed. In the process of installing the lift, I managed to break one of the rear sway bar links (rusted solid) and one of the shocks won't tighten completely (keeps spinning when I tighten the top nut and I don't have clamp big enough to hold the shock body). Other than that, it's done. Phew.
Old 02-03-2023, 08:02 PM #13
don't those have a hex indent on the top of the stud to insert a hex tool to prevent the turning?
fox , make , model , number , shock
5100 installation vs. spacer lift installation bandaman 5th gen T4Rs 28 07-20-2015 11:46 PM
sub installation johnpsmith84 3rd gen T4Rs 21 01-02-2009 11:35 AM
Ome Installation Denio 4th Gen T4Rs 4 05-01-2007 04:32 PM
new amp & speakers installation issue seconds2none Engines / Suspension / Wheels / Tires / Audio / Accessories 15 05-16-2006 05:36 PM
