Old 03-16-2023, 11:21 PM #16
J_Dizzle_777 J_Dizzle_777 is offline
J_Dizzle_777 is on a distinguished road
Lift kit alignment issues
Did you have any issues getting proper alignment without adjustable upper control arms? I see mixed comments about needing them for proper camber, etc.
J_Dizzle_777 is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 12:30 AM #17
TXST8SR5 TXST8SR5 is offline
TXST8SR5 is on a distinguished road
The Cali Raised low pro ditch light brackets came in today. Was planning to go with the CBI, but was intrigued when I saw the low profile option from CR.
Lights should be here tomorrow.
I also ordered the SRQ Fabrications body mount chop weld plates. It looks like their rounded style (and a couple others like them) remove the most material. They also appear to leave the cleanest, more factory look.....not that it is that big of a deal .
Next up is the Toytec 1" body lift.
Still trying to decide what wheels and what offset to focus on. How much negative offset to clear the UCA, but not too much to cause increased amounts of rubbing with 12.5" wide tires.
TXST8SR5 is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 09:44 PM #18
3" wide angle lights and Cali Raised brackets
Overbuilt 2wd build thread-21-jpg
Old 05-04-2023, 10:09 PM #19
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
I bought a lift kit that included upper control arms designed specially for my make and year. After a lift caster (not camber) is lost. Aftermarket control arms are required to fix the caster loss. This pushes the wheel towards the front of the truck to correct geometry after lift. And also you'll now have more tire clearance at the body mount and plastic junk in that area.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 05-05-2023, 10:28 AM #20
bigtimeweb bigtimeweb is offline
bigtimeweb is on a distinguished road
Originally Posted by TXST8SR5 View Post
The paint is decent overall, but shows its age. There are not many dings (surprisingly) but a few deep scratches. We will be looking at either a paint job or a wrap.
Hello neighbor! You can bring that paint back to like new with just a buff and polish and Dr Color Chip sells a fantastic paint chip kit. I have been working on mine a panel at a time because I have a broken shoulder, but heres my before and after of my hood, that's a one and done turtle wax on an orange foam pad and griots garage buffer, paint chips then turtle wax max wax on a black pad. the two of you together could prob do in a weekend no problem.
Also I have an aftermarket grille that will fit your car if you are interested. Its new in the open box. Were i-10 and beltway - ish
06 Sport v8 4x4
bigtimeweb is offline   Reply With QuoteReply With Quote
Old 05-05-2023, 07:48 PM #21
Also I have an aftermarket grille that will fit your car if you are interested. It’s new in the open box. Were i-10 and beltway - ish
A buff and polish is certainly not a bad idea. That would certainly help in the meantime.
How much are you asking for the grille? What brand is it?
Old 05-06-2023, 05:41 AM #22
The grille is from china. Its fairly straight forward install, as with all you will take some parts off your existing for the latching mech. you run the wires through the hood insulator down to driver side firewall. ground off a screw inside there at the kickpanel, attach an add a fuse to the positive and put it in your accessory fuse slot. I have the add a fuse as well. Im asking 150
06 Sport v8 4x4
Old 05-16-2023, 12:10 PM #23
We installed the CaliRaised low profile brackets and ditch lights yesterday. No telling what the actual angle of the lights will ultimately be, but that lined up with the angle on the top side of the brackets.
Overbuilt 2wd build thread-22-jpg  Overbuilt 2wd build thread-23-jpg
Old 05-30-2023, 07:24 AM #24
Finally got around to installing the new headunit. It is an Alpine iLX-W650. We didn't get past just the headunit, so we'll come back soon to install the backup camera, speakers, amps, etc.
We also installed the ProClip bracket and phone mount. Hands free for our teenager is the name of the game here.
Overbuilt 2wd build thread-24-jpg  Overbuilt 2wd build thread-25-jpg
Old 05-31-2023, 10:26 AM #25
Bl4ck4rm4 Bl4ck4rm4 is offline
Bl4ck4rm4 is on a distinguished road
Nice 4Runner, your son must be really excited. Very interested in seeing how the wheels work out.
Bl4ck4rm4 is offline   Reply With QuoteReply With Quote
Old 05-31-2023, 02:12 PM #26
tmhernandez77 tmhernandez77 is offline
tmhernandez77 is on a distinguished road
Always happy to see the younger generation wrenching on a vehicle. It's how I was raised and how I will raise my son as well.
tmhernandez77 is offline   Reply With QuoteReply With Quote
Old 05-31-2023, 05:45 PM #27
Thanks! He is definitely excited. We are kinda back to the drawing board on the wheels. I am looking for something with less offset. It is quite the balance to find something that will clear the UCAs but not stick out so far they cause other rubbing issues. I definitely do not want to buy new wheels just to run wheel spacers as well.
Old 05-31-2023, 05:51 PM #28
It was important to my wife and I that he is a part of the process. There is certainly a level of pride that comes with the hard work put in, and hopefully a level of respect that accompanies it.
We also have a custom golf cart project in the works. Our 9 year old daughter helps me with that because she is trying to claim her spot as driver
Old 05-31-2023, 07:15 PM #29
Talking
That's adorable. My son is 3 and my daughter is 1. First project for my son is to upgrade his jeep power wheel. He loves tools too, but a little too young for the real thing just yet.
Old 05-31-2023, 08:05 PM #30
I hear ya. I’m kinda in that same boat. I’m very skeptical on wheel spacers. It was a definite no no in the ford crowd due to possible breakage and losing your wheel.
2wd , fun , thread , toyotas , vehicle
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
