04 V8...would this leak cause a p0430? Also is this y pipe OEM?
Hi there,
Trying to bring my 2004 V8 4runner back to life. I got a p0430 All instructions pointed to find leaks first before a condemning CAT.. so I put a shop vac in reverse into the exhaust. Found a leak Right by passenger side downstream 02 sensor btwn the Y pipe and manifold cat.. Just confirming a leak here would this cause a Cat code? its right near the downstream 02 sensor, so I assuming it will and it should cause the 02 sensor to be jumping around.
Next, I was looking at the Y pipe. And looks the y pipe doesn’t look oem. Looks like the driver sides Y pipe flange was cut off and repaired. That seems like a solid weld that is still holding, but I can’t really tell if the Y pipe is original. it looks looks aged just like the original piping, but is it purposely restricted like this from the factory? The pictures of other y pipes i found on the internet look like they were for the v6… can with any one prior experiences let me know if factory y piping? Or did someone fab the Y pipe like that?
If that is a factory Y pipe, would the next logical step to bring my car to muffler shop to redo the header to y pipe flange? Its leaking btwn the two flanges and at the flange weld.
So I’m I correct in thinking that fixing this leak ‘should’ solve my P0430 ?
EDIT: If that’s not the factory Y, I could see why that restriction could cause the cat to burn up.
TY
2004 limited V8
2002 SR5 V6
