Old 02-05-2023, 08:17 PM #1
Mbdelta Mbdelta is offline
Mbdelta is on a distinguished road
4.0 Engine Coolant Leak From Behind Block
Hello friends,
I need some advice on a coolant leak that I have found. The coolant is dripping from near where the heater hoses attach to a manifold that is bolted to the back of the engine block. I can see three metal pipes on the manifold that the heater hoses are hooked up to. The middle pipe is dripping coolant. My question is what is that 'manifold' called and does anyone have experience fixing this issue. It looks like there might be a pipe coming out of the back of the block that this manifold is pressed onto for the middle pipe. Is it possible torquing the manifold down a little bit could fix my issue? Is there an o-ring or gasket where the manifold and block mate for that middle pipe? It's difficult to get in there and clearly see what is going on. Even more difficult to see what parts I might need when I don't know the name of that manifold. Any experience or advice would be appreciated!
Mbdelta is offline   Reply With QuoteReply With Quote
Old 02-05-2023, 09:10 PM #2
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
There is a rear water bypass joint behind the intake manifold. This connects to a heater hose and also to the back of each head. See attached. The water bypass joint in the rear connects to a crossover pipe using an o-ring. That sounds like it could be leaking. Each side of the rear bypass joint connect to each head using a gasket and 3 bolts.
zguy1 is offline   Reply With QuoteReply With Quote
block , coolant , manifold , middle , pipe
Coolant leak from block heater ericfromspace8 3rd gen T4Rs 2 08-18-2017 11:55 PM
where is the engine block coolant drain ? humboldtrunner 3rd gen T4Rs 2 04-26-2017 05:41 PM
rear coolant leak, NOT rear coolant bypass block... delgadog Classic T4Rs 11 06-13-2014 12:16 PM
Engine block leak? Mechanicaldan11 4th Gen T4Rs 3 11-01-2013 08:16 AM
4L engine block coolant drain plug, where is it? TC4Rnr 4th Gen T4Rs 4 10-21-2009 06:48 AM
