Old 02-11-2023, 03:38 PM #1
bricew25 bricew25 is offline
bricew25 is on a distinguished road
03-05 Pods in Fogs, Ideas?
I really want to replace my fog lights with some led pod lights. It seems like its easier to do with a 06-09, but not so much a 03-05. My favorite iteration of this is sold by SolidShift concepts, but it seems like they're always out of stock and dont reply often. Would be cool if they sold the STL file and people could print the part themselves. ( 2003-2005 4Runner Fog Light LED Mounts (Pair) – Solidshift Concepts )
Has anyone else rigged something up that looks good with their stock bumper? Just trying to get some ideas/ see if anyone has made it look good. Im tempted to hollow out the stock housing and fit one in there.
EDIT:
After lots of back and forth with 3D printing and trying to make something work, I settled on stuffing a 3-inch Baja Designs Pod in the stripped housing. I was really excited to discover a 3-inch pod would fit perfectly inside the fog housing. My original plan was to stuff it in, 3D print a new bezel and secure the pod light from the hole in the back of the housing. Of course nothing ends up the way you plan, so I cut some bottom out and actually have the light mounted to the bumper itself. Overall, its not perfect, but hopefully inspires some other people. Pics below
bricew25 is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 06:22 PM #2
monsterbuilder monsterbuilder is offline
monsterbuilder is on a distinguished road
Following. Let me know if you find any good solutions.
monsterbuilder is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 03:17 AM #3
Valize Valize is offline
Valize is on a distinguished road
Damn. I would buy a set instantly. Definitely following.
‘03 SR5 V8 296000k
Valize is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 12:50 PM #4
Surf13 Surf13 is offline
Surf13 is on a distinguished road
I may have purchased their last set available. I tried the both the Rigid (updated version from the SolidShift directions), and the Diode Dynamics SS3, but they were slightly too large for the opening. I ended up using Diode Dynamics SS2 in a combo beam. Looks and works well I think.
03-05 Pods in Fogs, Ideas?-2333-jpg
Surf13 is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 12:56 PM #5
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
The solidshift pods come back into stock every so often, and are definitely one of the cleaner options to mount lights to the bumper like that.
I ended up selling mine, I didn't like the fit issues with the lights I purchased and inability to adjust the aim really at all.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 01:24 PM #6
Which is why I went with the SS2.
Old 04-04-2023, 10:42 PM #7
I added a quick edit to my post on what I did for my 05 4Runner
Old 05-22-2023, 06:55 PM #8
CLOWNIN CLOWNIN is offline
CLOWNIN is on a distinguished road
Can someone post how you did the wiring? I'm getting ready to use some Baja Designs Squadron Sports and have figured out mounting just not the wiring part. My plan was to run them on the factory switch on the turn signal arm, but also do the fog light mod!
CLOWNIN is offline   Reply With QuoteReply With Quote
Old 01-09-2024, 11:32 AM #9
Usurper Usurper is offline
Real Name: William
Usurper is on a distinguished road
Real Name: William
Same here
Been looking for the same thing for awhile now, I can't seem to find anyone who was published how they have done it yet. Im looking at using a set of Squadron SAE lights.
Usurper is offline   Reply With QuoteReply With Quote
Old 01-09-2024, 09:21 PM #10
MikeinNH67's Avatar
MikeinNH67's Avatar
Usurper, it looks like no one replied to the question before your post so you may not get an answer. What exactly is the wiring question? Why can't you use the fog light power? LED has got to be less amperage than the original lights.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-10-2024, 10:30 AM #11
Real Name: William
Real Name: William
Wiring
I'm looking into this to see if anyone has experience connecting those new lights to the OEM wires so I can use the OEM fog switch on the turn signal. As I said before, I want to use Baja Designs squadron lights.
_________________________________________________
2005 4Runner Sport Stratosphere Mica
31.5 BFG KO2s
Old 01-10-2024, 11:14 AM #12
"baja squadron to xxxx (fog light bulb size) adapter"
I forget the # offhand but you can buy a premade adapter fairly inexpensively by searching that phrase. At that point it'll plug straight in and work off your fog light switch. It's also far lower draw than the OEM fogs so no risk of overloading the circuit.
Old 01-10-2024, 02:55 PM #13
Real Name: William
Real Name: William
Plug-and-Play LED Light Adapter Harness H10/9005/9006 - Baja
These should work fine then correct? Just posting them here to confirm and for others, if anyone else finds themselves in my situation.
31.5 BFG KO2s
Old 01-10-2024, 05:32 PM #14
Yep, that'll work.
Old 01-10-2024, 05:41 PM #15
MikeinNH67's Avatar
MikeinNH67's Avatar
Cool, I wasn't sure if you were trying to do more like always on with a relay or similar. Looks like you have a good solution.
Mike
03 4runner Limited
03-05 , good , ideas , sold , stock
New ARB bumper, new PIAA fogs to replace my factory fogs octanejunkie 3rd gen T4Rs 64 12-19-2017 12:09 AM
To Get Diffused Flood Light Pods Or Normal Flood pods Terbston 5th gen T4Rs 1 09-20-2017 03:11 AM
Factory fogs keeps blowing fuses - any ideas? Trevor C. 3rd gen T4Rs 12 03-25-2015 03:41 PM
Fogs as DRL's AND Fogs with High Beams? bobbyavidity 4th Gen T4Rs 4 04-05-2009 10:41 AM
