02-11-2023, 09:16 PM
Good Emblem Adhesive Remover
Removing all Emblems and most adhesive is coming off with Brake Cleaner except for the Edges of the Lettering. What works to get the little bit left off? But not damage my Paint.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
02-13-2023, 09:24 AM
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
02-13-2023, 04:28 PM
Hair drier on hot softens the glue,
Goof-off is okay
Acetone does a great job but test on your paint first
And a plastic scraper using straight dawn soap to keep it lubricated
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
02-13-2023, 05:00 PM
I was able to rub it off with some effort when I panted my emblems. Otherwise I use Goof-Off.
02-13-2023, 05:18 PM
Real Name: Thomas
Real Name: Thomas
+1 Goof-off
02-13-2023, 05:22 PM
+2 Goof-off
02-13-2023, 07:49 PM
Real Name: Skip
Real Name: Skip
Most seem to use Goof-Off, just an FYI, Goof-Off is 60% to 80% Acetone, 7% to 13% Xylene and 1% to 5% each of Ethylbenzene and Methanol.
Here's a link to the SDS (Safety Data Sheet)
https://content.interlinebrands.com/...4882_SDS_E.pdf
2004 Limited V8
02-14-2023, 03:08 PM
Real Name: Thomas
Real Name: Thomas
Originally Posted by auseeker
ftfy.
02-14-2023, 06:40 PM
Real Name: Skip
Real Name: Skip
Originally Posted by twbarrett
ftfy.
That smell will make you "goof off"!!
2004 Limited V8
02-19-2023, 01:34 AM
Goof Off did nothing at all.
02-19-2023, 11:30 AM
Real Name: Skip
Real Name: Skip
I have used WD-40 to remove some glues in the past, not sure if it will work on that adhesive or not, couldn't hurt to try it.
2004 Limited V8
02-24-2023, 11:00 AM
Sometimes you've got to let Goo-Be-Gone sit for 30 minutes then use a plastic wedge and everything comes off.
02-24-2023, 03:21 PM
Thank you for this info. I did not realize I needed to let it soak for 30 minutes. Thank you very much.
02-25-2023, 12:51 AM
Originally Posted by aemravan
Can vouch. This is the best.
‘03 SR5 V8 296000k
