Old 02-13-2023, 05:26 PM #1
pixologics pixologics is offline
pixologics is on a distinguished road
2004 ABS brake issue, need advice
Hello, I've a 2004 4Runner with 135k miles on it. For last few months it has been making squeaking noises too frequently that made me conclude that issue is coming out of ABS. There is no check engine light so far. But I want to get it fixed as noise is becoming too frequent.
I've already got all the brake pads replaced and also got the brake bleeding done to rule out issues related to brake pad noise. It does stops perfectly and I could not even tell any issue if it was not for this noise.
I showed it to some mechanic and he said that the complete ABS unit can be sourced from some Salvage part shops that sell used parts from old cars.
I also read on internet and found out that this is some kind of known problem in this model year.
Given that the brand new part is going to cost me north of $3000 plus, would you guys recommend getting the complete ABS unit swapped with another used one?
I was wondering what if the other unit also shows up this problem?Any suggestion or where I could locate better part in South California.
pixologics is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 08:02 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You can get a complete brand new OEM master cylinder with all the ABS components attached for around $1311 + shipping, here's the part number and a link to one for this price at McGeorge Toyota in Virginia.
Part Number ABS Modulator Valve - Toyota (47050-60081)
You can shop around using this part number...but you most likely won't find it for much less, also you won't find a price close to this from your local dealers...unless they sell online...dealers that sell online usually sell parts for much much less than they do at their parts counter.
Link
2004-2005 Toyota 4Runner ABS Modulator Valve 47050-60081 | Toyota Parts
That being said and posted, if you buy used make sure you get one that has the same part numbers as the one on your vehicle, this part varies a little form each year and they will not work if not from a 2004 or a 2005 year model. also only buy a used one with some kind of warranty the longer the better.
2004 Limited V8
Old 02-13-2023, 08:24 PM #3
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
It’s definitely not a $3000 part but it is pricey for sure. I just picked up that unit for $1300 from my local Toyota dealer. I think your cost on it runs roughly $1700. Used is an option but you could run into the exact same noise on a used one. I’ve also read people having them rebuilt but I’m not finding the answers I like to hear and read about for me to take a chance on a rebuilt unit. So I went new and am going to install and bleed it myself. Almost everyone with a 4th gen has to have this discussion with themselves and their runners! You definitely have options you just need to make a decision.
2004 ABS brake issue, need advice-30233a81-6f86-4cbd-a148-d0793b3d4492-jpeg  2004 ABS brake issue, need advice-65ea6e4a-8717-43ec-a60f-daac2f9077df-jpeg
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 10:47 PM #4
Thanks for sharing, this one seems to be complete ABS Unit. Can you please share the dealer name/location? Also, what is the part number in this case for complete unit?
Old 02-13-2023, 10:50 PM #5
Link
Great thank you, I looked online and I found that comparable part in Lexus dealership is priced less:
Lexus GX 470 Abs modulator valve. Brakes, brake - 4705060081 | Lexus of Orange County, Middletown NY
Do you think it would be exactly same for my 2004 4runner?
Old 02-13-2023, 10:54 PM #6
Great thank you, I am going try finding it out locally in CA. If expensive will order online.
Where can I validate that this part works for my car? I've VIN. But not sure if I can creep inside bay to be able to find part number as its mostly dirty.
Old 02-14-2023, 06:40 AM #7
Real Name: Skip
Real Name: Skip
It should be the same part, Lexus is made by Toyota and most parts are interchangeable between T4Rs and the GX470 series of similar year models.
2004 Limited V8
Old 02-14-2023, 01:47 PM #8
Bassturd's Avatar
Bassturd's Avatar
Same part number as mentioned above. Don’t forget to order your gasket when you order the booster it is a non reusable paper gasket.
2004 ABS brake issue, need advice-c91a07a1-42d0-4131-95f2-9f06fa4d1951-jpeg  2004 ABS brake issue, need advice-63aba60a-efc7-4d6a-95b4-7da99865152c-jpeg
2004 SR5 V8 AWD
Old 02-16-2023, 03:33 AM #9
Great thanks for confirming.
Old 02-16-2023, 03:33 AM #10
Thanks for letting me know. I'll add it to order.
abs , brake , noise , part , unit
Brake issue and need advice GaryL 5th gen T4Rs 6 12-03-2021 01:30 PM
2004 4R Brake Issue? 4RunnFunn 4th Gen T4Rs 8 02-21-2021 12:11 PM
2004 4Runner V6 issue?? mac777daddy 4th Gen T4Rs 3 07-08-2019 04:04 PM
2004 4WD clunking issue Pintlar Tactical 4th Gen T4Rs 5 10-18-2018 11:43 PM
2004 V8 - Coolant issue??? Powder_Hound 4th Gen T4Rs 14 07-13-2016 06:06 PM
