Old 02-13-2023, 11:09 PM #1
CelticRunner's Avatar
CelticRunner CelticRunner is offline
CelticRunner is on a distinguished road
Help- leaks when it rains above driver’s left shoulder
Been trying to research this issue and thought I found the culprit when I noticed the weatherstripping on the roof was missing but after a little more research that doesnt appear to be the culprit (Roof weatherstripping)
I only notice it when it pours, but in those cases the water seems to drop along the front left of the car and down into the dash (haven’t noticed any issues) or gets so saturated it just drips down onto the left side of the seat.
View from inside passenger seat looking up at spot: (red circle indicates location of spot; dashes indicate path of drips along front, by handle; verticals drips indicate drips down onto seat)
[IMG][/IMG]
Im wondering if it’s coming from the roof rack cover piece (these: Amazon.com: Tocatus Roof Cargo Rack Rail End Cover Shell Cap Trim for 2003-2009 Toyota 4Runner 4WD N210, Black, 4pcs : Automotive).
Has anyone else had a similar issue? Someone suggested just caulking around these rail covers but Im sure theres a better solution.
06 SR5, 190k miles (just breaking it in)
CelticRunner is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 06:54 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
[IMG][/IMG]
Those trim pieces for the roof rack brackets don't seal anything, they are only "trim" pieces, it could be leaking where the bracket screws to the roof, if I were to try and chaulk anything it would be the bracket to the roof, actually where the bolts/screws go into the roof is where it could be leaking, you would have to carefully remove the trim pieces to do that, but be careful as they tend to break from being brittle from sun exposure.
2004 Limited V8
Old 02-14-2023, 07:24 PM #3
Thanks, I was wondering if it could be something under there. Off to YouTube for videos…
Old 02-14-2023, 10:59 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
You do not have a sun roof correct?
Old 02-16-2023, 01:15 AM #5
shine shine is offline
shine is on a distinguished road
Might be worthwhile to remove the A-pillar cover and see if that helps pinpoint the source of the leak. Just remove the handle by snapping off the covers and removing 2 bolts with a 10mm socket. Then you can just pull the cover up and out.
My best guess is water coming in from the seal around the windshield.
shine is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 05:54 PM #6
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
A leak coming from the A-pillar is common when the drain for the sunroof (if applicable) is clogged with debris. Open the sunroof and clean the drain channel as well as the drain tube. Pour some water down the channel to make sure it's draining properly. I used a bicycle brake cable to clear the drain on mine when I had the same issue.
If you do not have a sunroof then it's likely a bad windshield seal.
Caution: Water coming down the A-pillar can get behind your dash along the firewall and wreak havoc with critical electrical connections located there.
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 08:54 AM #7
Correct, no sun roof, which is why I was so surprised. Still haven’t identified the cause and haven’t had time to try to take off the roof rack (though I’m a little concerned I’ll just break something else/more)
drips , left , noticed , roof , seat
Driver’s Side CV to Differential Looseness CutthroatSlam 5th gen T4Rs 2 09-11-2022 09:45 PM
Sunday Dinner: Latin Pork Shoulder RichinRidgewood Off Topic 4 03-14-2020 08:38 AM
Rear shoulder belts the_dingman Classic T4Rs 4 01-04-2011 03:57 PM
No more annoying shoulder belt on the trail glenyoshida 3rd gen T4Rs 14 11-08-2009 05:23 PM
shoulder seat belts for the rear on 86? Garth Classic T4Rs 1 07-13-2006 09:25 PM
