Originally Posted by AuSeeker
Those trim pieces for the roof rack brackets don't seal anything, they are only "trim" pieces, it could be leaking where the bracket screws to the roof, if I were to try and chaulk anything it would be the bracket to the roof, actually where the bolts/screws go into the roof is where it could be leaking, you would have to carefully remove the trim pieces to do that, but be careful as they tend to break from being brittle from sun exposure.
A leak coming from the A-pillar is common when the drain for the sunroof (if applicable) is clogged with debris. Open the sunroof and clean the drain channel as well as the drain tube. Pour some water down the channel to make sure it's draining properly. I used a bicycle brake cable to clear the drain on mine when I had the same issue.
If you do not have a sunroof then it's likely a bad windshield seal.
Caution: Water coming down the A-pillar can get behind your dash along the firewall and wreak havoc with critical electrical connections located there.
