Real Name: Ron
Real Name: Ron
I know what you're talking about, it prevents you from sucking the reservoir dry and refilling with clean fluid, I wanted to do same but didn't try and remove it, just bled a lot more fluid from each caliper and refilled.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
