02-27-2023, 04:11 PM
Bolt on Cat-Back exhaust?
Who makes a Bolt-on Cat-Back exhaust?
Something I can easily line up with the factory parts?
No welding?
Flowmaster?
Magnaflow?
Gibson?
etc???
CoopMA
Atlanta, GA - 2013 4Runner SR5, 2004 SR5, had a 1991 SR5.
02-27-2023, 06:02 PM
Real Name: Ron
Real Name: Ron
Walker. Inexpensive, installs in less than a hour, including removing old system and is lighter and just slightly louder than stock. Bolts right up. It may not last forever, but replacing it will be easy and cost effective again.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
02-28-2023, 09:28 AM
for cat-back, you can find the trd if they have it still, borla and toyota version is hard to find. magnaflow still makes 2 kinds of cat-back system i think. gibson is a hit or misss, i never used one.
you might be able to fit 5th gen exhaust / cat-back system i think, i only see the magnaflow did this so i cant really confirm.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK LTS pads F+R, Stoptech slotted rotors and stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
03-04-2023, 05:33 PM
Carven is making a catback… it’s short, it’ll dump in front of the rear axle so it’s a high clearance type. I saw it when looking at the one for our Tundra… ordered it (5-8 week lead time) but for <$400, a little better sound and clearance for Offroad, I was sold.
03-05-2023, 09:33 AM
if you have a v6, find a 5th gen take off. superior OE quality at a fraction of the price (i paid $50 for a new one). stay away from walker etc. cheap stuff rusts at the joints. you'll be shopping again just after the warranty expires!
03-05-2023, 06:38 PM
03-06-2023, 02:26 PM
Real Name: brian
Real Name: brian
Depends what you want, stock or performance. Like said earlier get 5th gen and cut down intermed pipe if you have a v8, bolt on for v6.
If you want performance magnaflow is nice. I have it on my '06 v8 and it sounds good., no problems for 3 years. Have the gibson elite on my '08 v8. Sounds better but not as well engineered. Does not fit as nice and I had to have it welded to keep its position. Plus the gibson tip is angled not straight so it looks like a blind person installed it.
If you can find a 4th gen TRD or Borla good luck. They are like hens teeth. i have a 4th gen TRD hanging in my garage made for a v6 but trimmed for the v8. It sounds exactly like the manaflow.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
03-07-2023, 11:55 AM
If you want performance magnaflow is nice. I have it on one of my v8s and it sounds good., no problems for 3 years. Have the gibson elite on my other v8. Sounds better but not as well engineered. Does not fit as nice and I had to have it welded to keep its position. Plus the gibson tip is angled not straight so it looks like a blind person installed it.
If you can find a TRD or Borla good luck. They are like hens teeth.i have a TRD made for a v6 but trimmed for the v8. It sounds exactly like the manaflow.
Thank you for the info! There is a TRD catback for the 5th gen 4runner local to me and I was thinking about picking it up for my '03 V8.
Did you need to chop the middle pipe down and get it re-welded to fit on your v8?
'99 Millenium Silver Limited
Toytec/Eibach coils on 5100's, OME 890 rear coils, 275/70R18 Duratrac on Pro Comp 18x9's
'03 V8 4X4 Limited
Asfir skid plate, Eibach Pro Kit, Wilco Hitchgate Solo, Retrofit headlights, 265/70r17 Grabber ATX on Motegi Trailites
03-07-2023, 05:31 PM
Real Name: brian
Real Name: brian
Yes. The middle pipe has to loose about 4-6 inches to work with the v8.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
