03-07-2023, 02:28 PM
#16
Originally Posted by phatcheeks
The dipstick should also say Type-IV on it.
When I did mine I changed it with Amsoil signature series ATF. Its been a few thousand miles already with no issues at all.
Ok, I will check that and see what it says.
03-07-2023, 03:29 PM
#17
Ok, correction
Just checked...
But no transmission fluid dipstick.
So I used the other ATF?
If I do a drain and re-fill of the fluid, what is the best way to go about it?
03-07-2023, 03:48 PM
#18
On Amazon,
This is the fluid I need for sealed transmissions?
Toyota 00289-ATFWS Automatic Transmission Fluid,
03-07-2023, 03:58 PM
#19
You still never gave the year...
You can download a copy of it here.
03-07-2023, 04:51 PM
#20
Dude!! Great link
Thank you
I have a 2008, V6 SR5
I did crawl under and found the trans fill bolt, does appear that WS is on it, from what I can see...very hard angle to see
So I ordered that fluid
Also ordered a pump to pump it back in.
03-07-2023, 05:09 PM
#21
Looks like I have the 1GR-FE engine
03-07-2023, 05:21 PM
#22
Real Name: Russell (OB #9908)
Originally Posted by MityMax96
Ok, correction
Just checked...
Yes, Toyota WS fluid.
Look at the top of the 4th Gen forum for this thread. Or search 4th Gen ATF drain and fill. You should get plenty of write-ups.
03-07-2023, 05:27 PM
#23
Will do
Thank you.
03-07-2023, 05:41 PM
#24
Will do
Thank you.
You're welcome. The trickiest part is confirming the correct fluid level. Be sure to have a thorough understanding of that process.
03-07-2023, 07:49 PM
#25
Real Name: Skip
Real Name: Skip
Dude!! Great link
Thank you
Yes as has been confirmed by others, you definitely need to use the WS fluid.
2004 Limited V8
03-08-2023, 06:02 AM
#26
how's the mileage? The thing is if its way overdue the damage is done.
A drain and fill wont do much if the clutches are worn out, I've rebuilt 2 transmissions one on my 03 4runner (A340F) on the 2018 and my 11 Landcruiser Prado (A343F) on the 2019.
Tried everything on my 4runner before rebuilding (Drain/fills, additives and changing solenoids) to be honest I'd say the additive did give me at least a few months of use while I made my decision.
I had a shift delay and on some occasions it would take some patience to shift into reverse when the Transmission oil was cold. So I parked in reversed everywhere I went.
Good luck
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
03-08-2023, 08:24 AM
#27
Yes I have been reading some instructions linked to in the threads mentioned here, as well as a YouTube vid I came across
So will read some more and make my step-by-step notes and do it
#28
Roger that
Thank you and it has been ordered.
03-08-2023, 08:27 AM
#29
Good luck
I am hoping it isn't a transmission rebuild, I just don't have the money for that.
So I am going to try my luck w/ the cheaper options first. That I can do myself.
But so far, the issue only started happening recently.....and even then it isn't as bad as the issue you had.
I had my 4Runner tuned...so that may have triggered the problem. But was probably going to happen regardless if I didn't have the tune done.
03-09-2023, 08:15 AM
#30
Another question, aside from transmission
At times, I am hearing a weird sound....almost like the sound you here when on rumble strips on the interstate.
Also maybe a slight grinding feeling when I hear the sound.
Any ideas what that is?
Axle seal?
Wheel bearing?
I believe it is coming from the rear, not the front
Reason: added info
