Originally Posted by Montego Murph
Since you found the broken wire, is there any way you could splice a piece in there to repair it? I mean, the end result can't be any worse than what's happening now.
so bit the bullet and cut the slot inside the cabin..stuck a pin inside the cut connection, glued it and joined the cut cable to it. the persistent p09xxx error code went away and i got 2 new ones p0713 and p0748 am thinking my continued driving of the truck with the initial error code may have made the fluid dirty. so i intend to drain and refill and refill the fluid and see how it goes. will buy a new harness if am able to get the Tranny MIL stay off
open to any other suggestions.
Edit: drained and refilled the tranny fluid but p0748 and P0713 MIL still persists. am thinking perhaps the solenoid is bad. who knows the exact solenoid responsible for p0748?
BlackWorksInc
, could you chime in here please.
2005 v6, galactic grey 4wd auto :
pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......
sold
2004 rav4 titanuim silver 4wd auto :
pionneer avhx 5500bt hu, pyle reverse cam
