Old 03-09-2023, 04:33 PM #16
MikeinNH67's Avatar
MikeinNH67's Avatar
Originally Posted by zguy1 View Post
I just cut it off. I fished a 40mm M10x1.25 bolt with a washer through the frame. It's a little long but I don't really care. After I put the nut and a washer on it, I will cut a slit in the end of the bolt with a grinder. This will allow me to hold the bolt with a screwdriver so I can tighten the nut. I guess I could always cut the bolt down with a grinder later but I don't think it really matters. I would never be putting a jack or anything under the fuel tank strap anyway.
I did the same with the front strap, didn't even have to slot it. The rear one needed the welding.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-09-2023, 05:05 PM #17
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Originally Posted by djpope09 View Post
Would this loaner kit from Autozone work like the Toyota SST? It looks like the one in the FSM. I am planning on pulling my tank soon and was going to try this kit out to get the retainer ring off.
https://www.autozone.com/loan-a-tool...kit/605758_0_0
Thank you, I am going to see if my local Autozone has it. Perfect timing too. I was about to put it back up and I couldn't get the ring into the area that the SM calls for. I don't think it would leak but I will attempt to get the tool and give it a try.
Btw, I can't believe I didn't even think of seeing if there was a rental tool for the job considering I rent tools from Autozone all the time. I actually rented a thread restorer kit just incase I needed to clean any threads during this job.
@MikeinNH67 ,
I'm glad to see I'm not the only taking this approach.
zguy1 is offline   Reply With QuoteReply With Quote
Old 03-09-2023, 05:13 PM #18
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Nice, definitely let us know how it goes. I can't remember how I found that one. I went back to find it for my reply and I had to look in the fuel system tools section. Most of the kit doesn't apply to Toyotas, but the retainer ring tool looks to be universal.
djpope09 is offline   Reply With QuoteReply With Quote
Old 03-09-2023, 10:53 PM #19
zguy1's Avatar
zguy1's Avatar
I was able to rent the tool from Autozone. It looks pretty solid but I felt uncomfortable cranking on it with a ratchet. I just grabbed both sides with my hands and gave it a good twist. I was able to get it right near the beginning of the target range. I'm happy were it ended up as it is right past another tab so it can not back off from where it is at now.
I was also able to grind a groove into the end of the bolt that I used for the one I broke. Once I got it tight enough using a screwdriver and wrench, I was able to switch to a torque wrench and tighten it per spec.
I added a gallon of gas and turned the ignition on. The low fuel lamp was illuminated. That's the first time I have seen it in months. I then proceeded to add another 4 gallons and now it is sitting between an 1/8 and 1/4 of a tank on the gauge which seems about right.
I also switched to a 30mm M10x1.25 and I am glad I did. It I didn't, I would have had to cut it down as it would have hit the gas tank proctector.
bolts , drive , fuel , protector , shaft
5th Gen 4runner 3rd row seat removal - step by step 4r-4ever 5th gen T4Rs 2 06-28-2021 02:21 PM
Fuel tank removal step by step, DIY w/pics the great him 3rd gen T4Rs 17 02-15-2021 02:41 AM
FREE 4th Gen Hood Protector, locking lug nuts, L OEM step rail in Seattle Doctor Subie Free 4 02-10-2021 02:35 PM
URGENT! Need help with Fuel Pump/Tank removal Zonly1 4th Gen T4Rs 4 05-12-2012 12:15 AM
Rear bumper 'step' Protector jhawk 5th gen T4Rs 9 10-08-2011 11:20 AM
