Originally Posted by rayray61
So all my lights came on VCS, engine light etc. They're all on and they stay on mechanic said codes are throwing out that all speed sensors are bad which he doesn't Believe is the case. Replaced the O2 sensor which didn't do anything so he's thinking it is the ABS control module but he doesn't know because he can't get a clear answer. Any ideas?????
Hi rayray61,
My 2012 L.E. is eleven yrs old now; but still has only 27,830 Miles on the clock... using a Com'l/Indus'l HVAC Service vehicle for work over the years! But, my L.E. has had it's share of DTC Codes thrown across the Instrument-Cluster ...many, many times! The trouble:
Yaw-Rate Acceleration Calibration & Center Point Steering Calibration issues; ...these problems came with the truck when I purchased it!
And like you said, the Instrument-Cluster lites-up like a new years-eve Celebration Tree; just w/o a Check-Engine light! I don't believe you lost ALL of your
Speed-Sensors for one minute! The way I calibrated the sensors requires NO Scan-Tool(s)! Just two pins to jump two ports in the
OBD-ll, #4 & #12 ...See link Below:
Yaw Rate and Acceleration Sensor Zero Point Calibration
Follow these instructions
EXACTLY as
iDRiVaT4R
has guided, and I think your troubles will be...
GONE!
Thank you iDrivaT4R for this FANTASTIC POST!!!
~rig~ Best to you!
