Old 03-14-2023, 01:47 AM #1
Bundutrailer Bundutrailer is offline
Bundutrailer is on a distinguished road
Anyone replaced viscous cooling fan? (Fan Clutch V6)
Hi
My viscous fan seems to have some weeping, should it be replaced or is there another way to fix,. At 95k miles all original including water pump, 2009 model.
Bundutrailer is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 08:18 AM #2
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
You are correct, if it's leaking it's time to replace.
I'd stick to the Aisin part since they're the OEM for it. Most of the aftermarket ones seem to have bad reviews for failing early, while many of the original fan clutches are still functioning after 15+ years.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 01:15 PM #3
Thanks it’s interesting I see nothing about this on this forum. What am I missing?
Old 03-14-2023, 05:14 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
Nothing, it just doesn't seem to be a common thing. Pretty sure mine is original at 20 years old and 220k. Yours is the first post I recall seeing about having an issue.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-15-2023, 09:19 AM #5
Search terms maybe? I get a bunch of results for the term "fan clutch".
Old 03-15-2023, 03:07 PM #6
Saw few only on V8 engine nothing on V6s. Mine is a V6.
Old 03-15-2023, 05:01 PM #7
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Hi
My viscous fan seems to have some weeping, should it be replaced or is there another way to step. At 95k miles all original including water pump, 2009 model.
You can buy the Aisin part from rock auto for about $90. Aisin is the OEM manufacture. I replaced mine when I was doing my cooling system overhaul, but there was nothing wrong with it.
The fan clutch usually doesn't go bad that early. Its pretty easy to replace though.
More Information for AISIN FCT072
Edit: its even cheaper on Amazon. And its Prime Amazon.com
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 03-15-2023, 10:07 PM #8
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
This search sucks. If I want to find something T4r I use google and get results from this forum.
Use this format
4runner fan clutch, forum site:www.toyota-4runner.org
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 03-15-2023, 11:27 PM #9
Thanks for this so Toyota is putting a 2x premium on its part? It’s exactly the same?
2004 Toyota 4Runner Engine Cooling Fan Clutch. Radiator - 1621050090 - Genuine Toyota Part
Old 03-15-2023, 11:27 PM #10
Old 03-16-2023, 05:59 AM #11
Real Name: Skip
Real Name: Skip
That one is for the V8, also that price is MSRP, you can find it for much less at other dealers who sell online,
Here's the one for the V6 from one of the best online dealers for price.
2003-2015 Toyota Engine Cooling Fan Clutch 16210-0P010 | Toyota Parts
2004 Limited V8
Old 03-17-2023, 01:37 PM #12
How bad is this, it works fine, no noises
Anyone replaced viscous cooling fan? (Fan Clutch V6)-screenshot_20230317_133833-jpg
Old 03-17-2023, 04:38 PM #13
Real Name: Skip
Real Name: Skip
Not sure what we're suppose to be looking at....BUT if all the oil leaks out you may not hear any noises, usually the main issue would be the engine not cooling properly, so keep a watch on the temperature gauge, if it goes even a little over "normal" I would stop driving and let it cool off, if you let the temperature go anywhere close to the maximum temperature on the gauge trying to drive a little bit further you could risk major damage to the engine.
2004 Limited V8
Old 03-18-2023, 04:22 AM #14
Sorry highlighted area weeping
Old 03-18-2023, 06:46 AM #15
Real Name: Skip
Real Name: Skip
I guessed that's what you wanted us to see, but it still doesn't tell us how bad the clutch is, it may still have plenty of oil in it and will work fine...for now...but when enough oil leaks out....then the rest of my prior reply is what advice I would give....other than to just replace it and not worry about it any longer, which you're going to have to do at some point and I would do it sooner than later.
The point I'm trying to make is it's worth spending a few bucks replacing it now than to have to spend a LOT of money later to replace or do major repairs to the engine.
2004 Limited V8
fan , including , replaced , viscous , water
Replaced under warranty, what have you had repaired/replaced? WandaRunner 5th gen T4Rs 40 12-29-2018 08:07 PM
1st gen overheating, newly replaced cooling system parts Computador32 Classic T4Rs 21 11-13-2014 11:44 PM
cooling fan always on avenged yoda 3rd gen T4Rs 5 11-03-2012 07:39 AM
WTB Cooling fan caddyman Want to Buy/Trade 0 04-09-2012 12:32 AM
Cooling... Kmvreter Maintenance/Detailing 3 09-05-2004 10:44 AM
