Old 03-14-2023, 09:14 AM #1
Tmaxxexpress's Avatar
Tmaxxexpress Tmaxxexpress is offline
Tmaxxexpress is on a distinguished road
Exclamation 2004 4wd v6 wont crank
This is a wild one. You turn the key and it will turn over but not start. No gas is what it seems like to me. I can unhook the battery and let it sit and hook it back and it cranks and runs perfect. Turn it off and goes back to turning over but not starting. Unhook battery and hook back up and starts. Seems to work every time this way. I have checked the fuses and relays. I have taken relays and switched them around and it does the same thing. I have tried different keys. same results. I took the throttle body off and cleaned it and still the same. It has been throwing the VSC lights for quite awhile but it ran for weeks with these on. Im at a loss. I have a cheap code reader and there are no codes thrown. Please help me to understand what is going on here. My rig is 2004 v6 4wd SR5. Thanks in advance
Tmaxxexpress is offline   Reply With QuoteReply With Quote
Old 03-16-2023, 11:26 AM #2
Nobody can help???
911 SOS help
Old 03-16-2023, 10:19 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Are you sure your battery is good? Id consider a crank test at an auto store.
Ive had symptoms like that with a bad ground before
Not helpful I know, but sounds more electrical if you can unhook the battery and it fixes the issue temporarily
Old 03-17-2023, 04:05 PM #4
MikeinNH67's Avatar
MikeinNH67 is just really nice MikeinNH67 is just really nice MikeinNH67 is just really nice MikeinNH67 is just really nice
MikeinNH67's Avatar
Most likely lost fuel pressure or ignition. Pull the intake boot and spray a bit of starter fluid or flammable brake clean into the throttle body. If it sputters or runs for a second then you have spark and you need to figure out why you don't have fuel. If nothing then most likely no spark which is tougher to track down.
Check your fuses and try and see if you can hear the fuel pump.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
4wd , back , battery , hook , turn
1992 4runner will crank for a long time then finnally start, then wont have problems timcarl450 3rd gen T4Rs 0 03-25-2013 05:23 PM
It wont crank! dadigab 4th Gen T4Rs 8 11-21-2012 06:19 PM
2004 t4r wont shift from 2hi > 4hi nismojason 4th Gen T4Rs 3 12-07-2010 11:23 AM
EL003-04 03/03/2004 Electrical - 'Crank Hold System' Jump Starting CBR_GUY_IA TSB 0 07-12-2009 10:35 PM
